Stupid question: Grover machines for slotted peghead...
Paul B
Post by Paul B » Fri Aug 29, 2008 10:17 am
Got a couple sets of Grover sta-tites for slotted pegheads today.
Can anyone tell me why they'd come with bushings? Both sets did and I can't imagine why, unless they are used on solid pegheads for some reason.
No big deal, just wondering...
TimS
ANZLF Approved Supplier
Post by TimS » Fri Aug 29, 2008 12:42 pm
Good question Paul!
I just recieved some myself. As I have used the LMI slotting jig I can't see where they would be located. Perhaps some suggeswted putting them just in case they could be used (as you say) for an unslotted set up.
regards
Tim
Post by kiwigeo » Fri Aug 29, 2008 1:17 pm
Duuno....maybe its on case youre changing out already fitted machine heads for the grovers?
Post by Richard » Fri Aug 29, 2008 1:20 pm
I installed Sta-Tites in my last slotted headstock and I didn't receive any bushings with them.
Can't imagine how they'd be installed in a slotted headstock... definitely seems odd.
Post by kiwigeo » Fri Aug 29, 2008 1:59 pm
From Stewmac site:
"Sets of 6 (3-left/3-right). Each set includes mounting screws and knurled press-fit peghead bushings. 11/32" (8.73mm) diameter pegholes required."
Paul B
Post by Paul B » Fri Aug 29, 2008 3:57 pm
Those are for solid headstocks Martin. These (part#4593 & 4593-G) are for slotted headstocks and for them it says "Set of 6 (3-left/3-right) with mounting screws. String posts are 1/4" (6.32mm) diameter."
Nothing about bushings... Maybe it's just a screw-up in the packing room. I was wondering if the bushings were there 'cause maybe some folks use them on solid headstocks on lapslide guitars - get a little extra height with these tuners or something? No big deal, as I said just curious. Extra bushings will come in handy at some point.
What is a, well ok, not a big deal, but certainly a pain in my ass is that the string posts are 0.02mm and 0.03mm bigger than spec, damn it. Now I gotta ream out my 1/4" holes, neatly, somehow.
They are nice tuners otherwise. Be nice if they friggin fit the friggin holes that I friggin drilled after looking at their friggin spec, frigg it!
Post by Allen » Fri Aug 29, 2008 4:26 pm
The Schallers that I put in my size 5 had bushings, and the instructions say to use them. It was a real pain to have to drill them out to the larger size after I had already drilled just for the shafts and then slotted the head stock. It really wasn't all that difficult to press the bushings in. I made a slight modification to the bushing press that I use on a paddle headstock.
And I just checked out a set of grovers that I have for a slotted headstock, and they have press fit bushings as well. There's no doubt about them being for a slotted headstock when you have a look at the string post. Thanks for bringing that to my attention Paul, or I might just have prepared the next headstock like the last one and had a bit of a fight on my hands.
Colin S
Post by Colin S » Fri Aug 29, 2008 5:53 pm
Just checked some Grover Sta-tite's, miked the shaft's and they are .249"-.250". Drilled a hole in some mahogany with the 1/4" bit and they are a tight fit, but not the tuners fault as they are within normal tolerances. Just gently reamed the hole with a 6.5mm bit and they are a perfect fit. On a head I'd probably ream the outside but leave the inside at a 1/4", for a really snug fit.
No bushings with mine.
Colin
Paul B
Post by Paul B » Fri Aug 29, 2008 7:17 pm
Cool, thanks Colin, I think I've got 6.5mm bit down in the workshop somewhere. I'll check it out tomorrow morning.
Post by Taffy Evans » Fri Aug 29, 2008 8:26 pm
Hi guys, Re the machines, yep same here with me.
I use the Stumac slotted peghead drilling jig, comes with the correct drills. Machines fit like a bum in a bucket.
Chopper
Stupid question:grover machines for slotted peghead
Post by Chopper » Thu Sep 11, 2008 8:19 am
For those still wondering, have a look at Taffys post on his' OOO finished and delivered' and you will see what he did with the bushings he received with his Schallers. This is what I do with slotted pegheads as well as I think it is better support for the string post and when you think about it, it is exactly the same as a vertical string post which always has a bushing of some sort. Very nice OOO Taff. My favorite guitar!
Post by Allen » Thu Sep 11, 2008 7:19 pm
It's what I did with my Schaellers as well. They are really nice tuners if you're thinking about going with a slot head.
