Hi All,
Does anyone have any experience in engraving an acoustic pickguard? I would like to engrave a pickguard a bit like on a J200 except not that design/style. When I look at the material available on Stemac, it is only 0.6mm, which would seem much too thin to engrave. (LMI a bit thicker at 0.7mm) Any options or advice on how I might approach this/materials suggestion etc would be greatly appreciated.
Engraving a pickguard
- lamanoditrento
Re: Engraving a pickguard
Can you link to the product you’re talking about? I can’t imagine any pickguard material only half a mm thick.
Most hand engraving is done with a tool that is simply a metal spike, there are different shaped and angled spikes and you simply drag them across the surface.
Me personally, I don’t have the skill for that so I’d draw it in CAD and do it on CNC with a similar style cutting bit to what would be used as a hand tool.
- lamanoditrento
I was looking at this https://www.stewmac.com/Materials_and_S ... lanks.html
What material do you normally use Allan?
I checked the link and you’re spot on, it really is that thin!lamanoditrento wrote: ↑Thu May 09, 2019 7:24 amI was looking at this https://www.stewmac.com/Materials_and_S ... lanks.html
I guess now I think about it an acoustic pickguard should be super thin to limit its interference on the top vibration.
Something that thin on the CNC I would not use a standard routing/engraving bit, I have a spring loaded diamond engraver I use on odd jobs and I’d do it that way.
Doing it by hand you’d still use the scribe type tool I mentioned earlier.
To answer what I use, I don’t put pickguards on my acoustics which would be why I’m not familiar with the range of materials, I have put pickguards on some electrics and it’s been the thicker two/three ply type stud which you wouldn’t put on a acoustic.
