fretboard radiusing router bits
blackalex1952
Post by blackalex1952 » Sun Nov 10, 2019 1:37 pm
I just bought one of these radiused router bits for my fingerboards...I'll report back when I have tried it!
https://www.amazon.com/Yonico-13005-Rad ... ter&sr=8-1
They are available in a few radii so I bought the 16" radius and will use sanding blocks for refinement into a conical fingerboard.
Cheers! Ross
asgilbert
Re: fretboard radiusing router bits
Post by asgilbert » Mon Nov 11, 2019 11:53 am
Looks like an awfully large bite Ross. Might chatter due to too the surface area of the cut!! But what would a metal worker know about wood!!
blackalex1952
Post by blackalex1952 » Mon Nov 11, 2019 1:32 pm
I'm not too worried re chatter as I intend to make light passes, using an adjustable fence on the router table, along with a jig to hold the work using double sided tape. Then I intend to radius the fingerboard with radiused blocks, ending up with a 12" radius at the nut end and a 16" at the soundboard end..conical is good! IMOP. If the system works fine I'll order a 12" and a 14" to speed things up a little more. My usual method is to use a combination of a hand plane, different radius blocks then a sandpaper straight edge prior to fretting in a fret press. I am hoping for some comments from luthiers who have actually used one of these bits.- Cheers! Ross
RodC
Post by RodC » Mon Nov 11, 2019 5:31 pm
I've recently used just that sort of bit to radius my fret board.
No problems with chipping or chattering, but I went quite small on the increments - so wasn't taking much off per pass.
I still used a radius sanding block to finish though.
My fret board is cook town iron wood with maple inlay.
Steve.Toscano
Post by Steve.Toscano » Tue Nov 12, 2019 9:03 am
Out of interest: What's the motivation, or what are you attempting to fix, by using such a method for radiusing fretboards? Versus using more 'traditional' methods?
Is it an accuracy thing? A time thing?
RodC
Post by RodC » Tue Nov 12, 2019 9:56 am
For us it's mostly a time thing.
It is quicker and simpler than the other methods we have tried.
Post by kiwigeo » Tue Nov 12, 2019 11:33 am
For me it would simply be a time thing....but at my current build rate over all time saving would be minimal. I'd also miss the joys of getting covered in ebony dust and building up the shoulder muscles on my right arm :mrgreen:
Steve.Toscano
Post by Steve.Toscano » Tue Nov 12, 2019 2:07 pm
Fair enough, each to their own.
Although i struggle to see the time saving using such a method, unless you are mass making fretboards, which i doubt anyone on this forum is doing.
Feels like another over engineered, messy, and noisey, process for the small time builder.
Takes me ~15mins to radius my ebony boards up to 800grit using traditional methods eg nothing but a well tuned handplane, a shooting board, and a radius block with abrasives. Not much longer for a well attentive student.
It would probably take me longer just to find the router bit in my workshop :oops:
Let alone the hell of a mess it makes, the noise, and the safety concerns of using such a large bit.
If enough people are interested in a more traditional process I'm happy to do a video on it over the Xmas break.
RodC
Post by RodC » Tue Nov 12, 2019 2:39 pm
I would love to see that Steve.
Andos
Post by Andos » Tue Nov 12, 2019 4:47 pm
Count me in Steve.
Post by 56nortondomy » Tue Nov 12, 2019 4:49 pm
I'd like to see how you do it too Steve.
Alain Lambert
Post by Alain Lambert » Wed Nov 13, 2019 1:12 am
Post by Allen » Wed Nov 13, 2019 6:43 am
I use the CNC to built the entire compount radius board, including purfling lines, inlays and stopped fret slots. And go about other things while that is happening. :D
blackalex1952
Post by blackalex1952 » Wed Nov 13, 2019 11:49 am
All along I thought you were doing that with beer!
Gazm
Post by Gazm » Fri Nov 15, 2019 1:22 am
I'm keen too see your method also Thanks Steve.
TallDad71
Post by TallDad71 » Fri Nov 15, 2019 2:09 am
I’ve built all manner of radius sanding blocks with depth stops. I HATE IT. It’s the only part of luthierie I don’t look forward to.
Just dropped £90 on a custom set Spindle Mould cutters to get a run of 10 fretboards radiused and built a jig on a table saw to cut frets slots. I’m very much hoping tri get similar results to the OP with the router bit
Love to see your method Steve.
Peregrine Guitars
Steve.Toscano
Post by Steve.Toscano » Fri Nov 15, 2019 8:11 am
No worries all.
I'll endeavour to record a video on this over the xmas break and will post back here when available.
Post by 56nortondomy » Fri Nov 15, 2019 12:13 pm
Looking forward to that Steve, thanks.
Regards Wayne
peter.coombe
Post by peter.coombe » Tue Nov 19, 2019 10:17 am
Mmm, WAY too much stress over what should be a simple easy and quick job. I took one look at the router bit and thought NO WAY, far too dangerous, and for what? I rough out the radius on the linisher, then install the fret maker inlays, then rough out on the linisher again, then a final sand using the radius block and polish it up with 1200 wet/dry (used dry of course). I can usually get it pretty close on the linisher so that the effort with the sanding block is minimal, but then I have done hundreds of fretboards like that so have plenty of practice. The actual radiusing process takes maybe 15mins max, and very little sweat. Occasionally I get an Ebony board that insists on bending, but a bend can be straightened out with a wipe of moisture on one side. Easy. The only thing I don't like is the Ebony dust.
Users browsing this forum: Google, Mark McLean and 109 guests
