Thought I posted a similar recently, but trying again:
I see variations on how face and finger braces, and the bridge plate, interface to the X-braces. Some builders prefer that there are no connections, with an intentional gap. Others want a connection.
G&G recommends the latter, with the braces butted up against the X but scalloped down to 2 mm. The X arms are also butted directly against the bridge plate, presumably glued there too. The latter seems to make some sense, intuitively.
Neither method is a challenge to build, but I am interested in any structural benefits, or risks, to either approach.
Comments appreciated.
thanks
Kevin
X-brace interfaces
Re: X-brace interfaces
Tapering down to 2mm at a butt joint between braces is essentially unconnected as far as any bending strength. What you are trying to avoid here is something like a full height butt joint which if it were to crack apart could buzz,
Some older Martins connected finger braces and bridge plate to the X braces by "tucking" them under the X brace for a few mm. This has fallen out of favour as it is more work in building and makes repair difficult.
