Big sheets of sandpaper
nkforster
Post by nkforster » Sat Mar 07, 2020 4:32 pm
I'm after big sheets of abrasive, minimum 420mm wide. In Europe, I used to buy the sanding belts for wide belt sanders and cut them up. I'm a bit stumped here. Any suggestions?
Mike Thomas
Re: Big sheets of sandpaper
Post by Mike Thomas » Sat Mar 07, 2020 6:20 pm
https://www.thesandpaperman.com.au/
Have you tried The Sandpaperman?
Mike Thomas
WJ Guitars
Post by WJ Guitars » Sat Mar 07, 2020 6:40 pm
Google 'WM Workmate Abrasive Specialists'.
This where I purchase my sanding sheets from. They have a vast range of sand paper products.
Welcome to Workmate Abrasives | Workmate Abrasives ..Contact Us
Contact Us. SYDNEY Workmate Abrasives Pty Ltd P.O. Box 186 ...
Woodworking
Sanding Rolls – Raptor Gold. More Info. Floorsanding Belts ...
Catalogue
NSW 02 9774 1111 / SA 08 8277 8833 / VIC 03 9770 8877 / QLD ...
Bruce McC
Post by Bruce McC » Sat Mar 07, 2020 7:17 pm
+1 for the Sandpaper Man
www.TheSandpaperMan.com.au
In Wynnum Qld. Phone 07 3396 4457.
Bruce Mc.
nkforster
Post by nkforster » Sat Mar 07, 2020 7:26 pm
Thanks fellers. From what I can see, neither of those firms have what I'm after. Nothing bigger than A4.
Those of you who use spherical formers for "driving the bus" where do you get your paper from?
Bruce McC
Post by Bruce McC » Sat Mar 07, 2020 8:37 pm
Hi Nick
I have purchased sanding discs 610mm diameter and drive belts for my Jet 16/32 drum sander
that are 410mm wide from the Sandpaper Man in the past, (5-10 years).
Bruce Mc.
WJ Guitars
Post by WJ Guitars » Sun Mar 08, 2020 7:41 am
Those of you who use spherical formers for "driving the bus" where do you get your paper from?/quote]
You can order from WM Workmate adhesive disc shape paper cut to the diameter size you require. You would need to give them a phone call to arrange a specified order.
nkforster
Post by nkforster » Sun Mar 08, 2020 8:20 pm
Looks like I may well be getting some from China. But I'll be buying quite a bit. 450mm wide. 60 grit. Any use to anyone?
asgilbert
Post by asgilbert » Mon Mar 09, 2020 12:05 pm
This from beyond tools in Perth
https://www.beyondtools.com/?s=Sandpape ... lter%3AAll
330 wide but long rolls. I used for my dishes etc.
Users browsing this forum: No registered users and 226 guests
