335/archtop style question
I've been thinking lately about one of my favourite electric guitar types - the 335. In particular, I've been thinking about how the tops and backs are carved out of a thick billet. Seems a bit wasteful to me and I was wondering if the top and back of a 335 style could be made domed across the whole surface like an acoustic. I know, it won't look exactly the same, but I think it would vastly simplify the body construction. Has anyone seen a 335-ish shape done this way?
Re: 335/archtop style question
The 335's have laminate tops and as far as I'm aware also laminated sides and backs. A vacuum press might be a good aquisition at this stage
Here's one guys method: https://silo.tips/queue/making-an-es-33 ... dkOmY1YjA=
This may also help: https://youtu.be/Agj-PRrwWZQ
My first thought is no.
Even if you were willing to sacrifice its appearance A little.
The main body wouldn’t be so bad but you would lose the concave to convex change at the edges, the wing tips are very curved and a laminate would really struggle here over a former. Then you have the loss of any solid wood in which to house the pick-ups and bridge in, and that bulk does a lot of the work for attaching the back half.
You would also need to carve a former to shape it to, in which case you may as well go ahead and just carve the top.
Sorry! A bit pessimistic there.
Peregrine Guitars
Peregrine Guitars
- 56nortondomy
The other thing to consider is you wouldn't be able to carve a re curve around the edges and that is a big factor in the sound of these types of guitars.
Thanks for the replies. It's a thought provoking topic.
