Shellac and other finish
KreherGuitars
Post by KreherGuitars » Sat Jun 05, 2021 8:09 pm
Recently finished my first French polish. Took a long time to get it looking nice. And I’m not really impressed with the finishing method. The slightest touch of a fingernail will make a crater. I have experience with nitro and prefer the end result. I don’t have access to a spray room anymore. So I’m looking for a brush or rub on finish. Is there a shellac that I can buy that is more dense? Or way to spice up the recipe to make it harder? And or is there recommendations for an alternative finish? I have been thinking about crystalac water based. Please give me all your recommendations and advice
Re: Shellac and other finish
Post by kiwigeo » Sun Jun 06, 2021 8:09 pm
Try hard shellac. I use the hard shellac produced by Shines. Trevor Gore also uses it on his french polished instruments.
johnparchem
Post by johnparchem » Sun Jun 06, 2021 11:45 pm
I use Royal Lac, a modified shellac that is much more durable on some of my instrument. Using straight shellac I find that it takes about a month before the finish truly cures. Even longer if the finish is thick. Once cured shellac stands up to normal wear and tear.
Post by kiwigeo » Wed Jun 09, 2021 9:20 am
Normal shellac is surprisingly durable if you give it time to cure properly. All of my early builds were french polished with straight shellac and are still looking ok after 5 years of use by a guitarist in an Indie band
yakka
Post by yakka » Thu Jun 10, 2021 10:51 am
