Grain Runout
TKAY
Grain Runout
Post by TKAY » Fri Jan 07, 2022 9:33 pm
How important is grain runout when choosing bellies ? I have only made a Lute with AAA Sitka. Beautiful timber with over 40 rings /inch but certainly not a split belly. As the Rose is carved into the top one certainly needs the superglue handy. Any thoughts appreciated
Tom.
Re: Grain Runout
Post by kiwigeo » Sat Jan 08, 2022 9:23 am
Run out can be a pain if you thickness your tops mainly with hand tools.....I always had planing direction penciled clearly on each side of the top. These days I use drum sander for most of my thicknessing.
Re: Grain Runout
Post by Mark McLean » Sun Jan 09, 2022 9:39 am
Runout is not thought to have bad effects on sound quality of instruments. If you book match a two piece soundboard with runout you get a different appearance of the colour of the timber under finish in each half.
This is a cosmetic problem rather than a structural one, but some people would not buy a guitar with such a top because they don’t like the way that it looks. Extreme runout could make the soundboard weaker or make a glued bridge more likely to detach.
There is a useful discussion by Frank Ford at trets.com
http://www.frets.com/FretsPages/General ... unout.html
