new classical with spectrum
Jim watts
Post by Jim watts » Mon Mar 28, 2022 1:30 pm
Just complete this.
Honduran Rosewood and spruce 7 fan open harmonic bar classical
A v-joint on the head stock which was something I've been working on
I'm pretty happy with it as it sounds and plays pretty nice.
I was pleased that I was able to get the spectrum into the range I was shooting for.
IMG_3738 resized.JPG (43.51 KiB) Viewed 11924 times
_MG_8599 resized.JPG (34.93 KiB) Viewed 11924 times
_MG_8609 mall.JPG (191.8 KiB) Viewed 11924 times
_MG_8602 cropped v-joint 1.JPG (134.3 KiB) Viewed 11924 times
johnparchem
Re: new classical with spectrum
Post by johnparchem » Mon Mar 28, 2022 2:25 pm
Very nice guitar! I really like the guitars I made pitched around 190 Hz for the top. I love how the headstock joint worked out.
Dave M
Post by Dave M » Wed Mar 30, 2022 2:37 am
Yes very nice work. Dave
Post by kiwigeo » Wed Mar 30, 2022 3:33 pm
That's a nice tidy looking guitar Jim. Well done with that V headstock joint.
Semmens Guitars
Post by Semmens Guitars » Sun Apr 03, 2022 6:52 pm
Great work there Jim!! Love the neck join and the rosette looks sleek too.
:cl :cl :cl
Jim watts
Post by Jim watts » Sat Apr 09, 2022 12:22 pm
Thanks for the nice words guys!
Post by Mark McLean » Sat Apr 09, 2022 8:02 pm
Great work Jim. Looks fantastic. Do you have any photos of the V-joint of the headstock in progress? The end result looks great.
Jim watts
Post by Jim watts » Sun Apr 10, 2022 12:13 pm
Hi Mark, I have a couple of photos.
The things that helped me most were a wide super sharp chisel, 25mm was my widest, a marking template that can very accurately mark the joint all around the neck and a highly repeatable clamping method for test fitting and final glue up.
The photo below is my marking template, this allows me to mark the top and bottom of the neck using the same reference side of the neck blank. I put a 10 degree angle on the neck shaft side so I align the template to a 10 degree line scribed on the side of neck shaft.
The pin in the picture is removable so it comes out for marking the neck shaft. The same template marks the peghead side. The pin is used to control the template depth on the peghead side. I cut the peghead slightly deep and dropped the peghead down onto the shaft by planing the end of the peghead on a shooting board. I hope that all makes sense! It takes some finessing after that, but the better your layout the less finessing required.
v-joint making template.JPG (69.24 KiB) Viewed 11549 times
The next photo is my clamping arrangement. the peghead is placed up against the bottom side of the upper block, then the shaft is pushed into it with my end vise. It's a little cobbled together, ok a lot cobbled together but it worked very well. Pat Foster gave me the idea for this, I'm not sure if he's a member here or not.
clamping v-joint.JPG (62.81 KiB) Viewed 11549 times
Hope that helps.
Post by lamanoditrento » Fri Apr 15, 2022 1:04 pm
Very nice Jim. Great work on the v joint :cl
