Fox Bender Problems
Peter Lynch
Fox Bender Problems
Post by Peter Lynch » Wed Sep 21, 2022 4:21 pm
Hi all ,
while I practise with my new bending iron I will still need to use my homemade Fox Bender utilising a heat blanket and stainless steel slats . The stainless steel slats I am using ( .6mm thick ) have taken on the shape of a guitar side and make the setting up of the side to be bent awkward and clumsy . I am wondering if other forum members are using either thinner slats or another more flexible material that will withstand the temperature involved ( say up to 150c ) that would make the task easier ?
Bob_H
Re: Fox Bender Problems
Post by Bob_H » Wed Sep 21, 2022 6:04 pm
Hi Peter - you might want to look at spring steel - it shouldn't hold the shape. You can pick it up fairly cheaply through Aliexpress, or even possibly LMI in the USA. I recently asked a few local steel suppliers but it couldn't find a local provider that came close to matching international prices (perhaps i just don't know the right people!). Someone else on the forum might be able to suggest a local supplier.
Bob Holbert
Lyndoch
Dave M
Post by Dave M » Thu Sep 22, 2022 2:07 am
Yup had the same problem. Spring steel is the answer though since it rusts you need to wrap the wood in Al foil to keep the moisture off the steel.
I couldn't find a supplier in the UK and ended up buying from - was it LMI or Stewmac...? Again as Bob says perhaps I just didn't know my way round the metals market.
Post by Allen » Thu Sep 22, 2022 5:16 am
I use Aluminium roofing flashing instead of stainless or spring steel. As you found out the stainless is just a PITA and spring steel rusts. Especially when you live in the wet tropics. Flattens out easily after use.
I use a piece on either side of my timber. Also use a piece to back up timber when bending on the bending iron
Go into your local building supply (Bunnings) and get yourself a roll. I've been using the same pieces now for 15 years and many hundreds of instruments.
joel
Post by joel » Thu Sep 22, 2022 9:37 am
Allen, thanks for the brilliant tip!
Do you use the 0.3mm or 0.7mm stuff?
https://www.bunnings.com.au/consolidate ... h_p1100453
https://www.bunnings.com.au/consolidate ... h_p1106554
Post by Allen » Thu Sep 22, 2022 1:44 pm
Probably 0.7mm. Never measured it and like I said it's been around for 15 years or so.
0.3mm I think would not provide much support.
yakka
Post by yakka » Thu Sep 22, 2022 4:09 pm
Aluminium Flushing is very good
regards
Chris
Peter Lynch
Post by Peter Lynch » Sat Sep 24, 2022 3:50 pm
Thank you everyone for your suggestions , I have ordered a set of spring steel slats from LMI , should do the trick .
Thank you again for taking the time to post your suggestions
