I want to make my own control knobs for an electric guitar but cannot find a source for brass or plastic inserts to fit the 6mm, 18 flute split shafts of the Bourns potentiometers I have. Plain, 1/4" inserts are available but nothing to suit these very popular pots. Bourns themselves have not bothered to reply to my enquiry, I was surprised they don't sell them themselves.
There is no shortage of knobs with inserts fitted available from many sources online so somebody must be making these things by the million. Does anybody have a link to a source, or will I have to buy some existing knobs and attack them with hammer and chisel?
Kit
Knob Inserts
- 56nortondomy
Re: Knob Inserts
I made some knobs a while ago. I used brass inserts, I drilled a 6mm hole to go over the shaft then I glued that into a wooden knob I turned on a lathe then drilled through the side and threaded to take a grub screw to lock it in place. Hope that helps.
Re: Knob Inserts
Thanks Wayne.
I do have a metalworking late I can use to make something similar to your description if necessary, but I was hoping to find a supplier of inserts designed to fit the knurled shafts of the pot. Plenty of other people seem to have access to them, but I can't find any link to a supplier.
Something I found very surprising was the lack of any information on Bourns own website. They make the pots, I'd have thought they'd have had some info on making knobs to fit them!
Re: Knob Inserts
These look like they may do the job for you.
https://www.ebay.com/itm/202482591760
- lamanoditrento
Re: Knob Inserts
If you search for a 'one-piece collet with set screw' you will find thousands of suppliers.
https://www.amazon.com/SC-1-Solid-Shaft ... B01MR351PF
https://www.makerstore.com.au/product/lock-collar/
I've assumed the post is 1/4".
Re: Knob Inserts
Mark,
You just have to work out the correct search term! Than you for that link. I need the knobs to be quite thin (more thumbwheel than knob) so those plastic bushings ones will be easier to cut to size than metal ones.
Trent,
The Bourns spec sheet (and my digital caliper) says the shaft diameter is 6mm and most collars are 1/4", though your Makerstore link has both sizes. Coincidentally they also have 5mm which is one I need for a completely different, non-guitar project, so thank you very much for that!
Kit
Trent,
Kit
Re: Knob Inserts
one solution I have used is somewhat wasteful but it works.
Buy a plastic knob with the grub screw and brass fitting and crack off the plastic. You can then re-glue the brass insert into your custom crafted knob.
A bit agricultural I know!
