I find this unit very helpful when doing jobs that require me to work all around a guitar, such as in installing binding, purfling, and also fitting tops and backs. I can just sit [rarely] or stand in the same
spot. And in my cramped workshop that’s a bonus.
As you may notice the metal parts were salvaged from an office swivel chair…
It can be mounted on my island vice, or clamped to a bench top…
The only thing I had to supply was a bearing [from the front wheel of my trials bike…
I have different tabletops that match the size of the guitar I’m working on, which are then located on the pins in the base table…
I also place different risers on the table's perimeter this allows for the radius of the top or back, and allows the guitar to sit flat on the table…
I can use tape, rope, or clamps and just spin the whole assembly around as required…
It works for me.
Lazy susan worktable...
- Taffy Evans
Re: Lazy susan worktable...
Taffy you are a very canny fella. Do you have stacks of jigs and tools in your kitchen and in your car too - or is this habit confined to luthiery activities?
- Robert Gleason
- Kauri
I use lazy Susans too, but not being as tricky as Taffy, I just buy a $20 lazy Susan bearing at a hardware store or on Amazon. I have a few and use the 12" size. Takes maybe half an hour to make a useable unit out of a couple of pieces of plywood. My main use is to hold go-bar decks for easy glue clean-up. Useful in the dining room too!
