This is the type:
https://www.guitartemplates.com.au/1-4- ... rcuit-long So nothing to really hold on to that won't also probably harm the finish.
Thanks Martin, its the surrounding french polish I would worrry about... need to get locktight up to 200 degrees, so I think that is a no go.
Thanks Taff. Appreciate the response. No need to hold on to the nut its, captured and glued in the block, so it won't turn which is good because there is no access, so will be buying me a pair of circlip pliers.Taffy Evans wrote: ↑Sat Aug 17, 2024 3:52 pmHi Trent, I was all ready to post photos of how I would tackle that problem but found that a recent computer service had removed my photo program, and I have not worked out how to get around the problem yet. So I will try to explain it.
First, you need to grip the body of the jack. To do this:
* I have a pair of circlip pliers that open out when the handles are squeezed.
* I place the pliers into the plug access hole in the jack and squeeze to hold the jack from outside of the guitar, this stops it from turning.
* To turn the nut inside I have a tube spanner with an extended handle that I apply to the nut on the jack inside the guitar through the soundhole.
* I cut a slot in the tube to allow the wire from the jack to pass through. I would feed the wire into the slot in the spanner then run the spanner down the wire onto the nut.
* Whilst gripping the outside pliers tight you will be able to turn the tube spanner and break the seal of the thread lock. I hope.
Good luck Taff
Short answer: I thought I was smarter than I was and acted more stupid than I should be.
