Classical guitar bridges
BruceSmith
Post by BruceSmith » Wed Oct 16, 2024 1:41 am
Good day, I am building a classical with bridge plate. Does anyone know if I put together Mr. Gore’s bridge design outlined in the Build book edition that specs laminated carbon fiber and just use solid quarter sawn instead if it’s footprint is large enough? It is approximately 20mm shorter than traditional designs. Thanks, Bruce
Re: Classical guitar bridges
Post by kiwigeo » Wed Oct 16, 2024 7:44 am
Trevor's bridges incorporate CF in order to add strength and keep bridge mass down. The more mass..the heavy the top and the more string energy required to drive same. Using Trevor's wood/CF sandwich construction you can use less dense woods like walnut and end up with a bridge that is super light but strong.
BruceSmith
Post by BruceSmith » Fri Oct 18, 2024 1:32 am
Thanks Martin, Would you know what thickness carbon fiber sheet is recommended for laminating?
Post by kiwigeo » Fri Oct 18, 2024 7:10 am
Discussed in this thread: http://www.anzlf.com/viewtopic.php?t=3624
BruceSmith
Post by BruceSmith » Fri Oct 18, 2024 7:44 am
Thanks again Martin!
