Help with analysis
Help with analysis
this is a top with bracing inspired by the Gore Gilet books...I will post a pic from my pc shortly, on my laptop at the moment, New to this VA program...
Re: Help with analysis
here is the bracing layout
- PICT0107.JPG (145.01 KiB) Viewed 10769 times
Hi,
Is this the frequency responce for the finished guitar including the bridge? What type of guitar, steelstring classical? Also the white number are hard to read.
Luke
Luke
Bridge patch shape suggests its a steel string. Circa 100Hz peak looks like an air resonance peak so this would suggest the top is on the guitar when analysis done.LUKE_LEE wrote:Hi,
Luke
finished steel string guitar, strung up
- DSC00365 (426x640).jpg (193.07 KiB) Viewed 10681 times
numbers are 103 , 185, 194 ,218 , 244 , 283, 327 , 389 , 456
- woodrat
Hi Wes...did you put the side weight attachment points in to trim body resonances? Your 185 needs to go down 5 Hz to start with and side weight is an easy and effective way to do it. I put them in all my guitars now.weslewis wrote:numbers are 103 , 185, 194 ,218 , 244 , 283, 327 , 389 , 456
Wes have you done any Chladni testing? Im currently in the process of doing same on my falcate classical.....the discussion may be of use to you.
not yet, guitar has been finished for several months and sounds really good, prototype design i have another in process with falcate bracing so i can compare
