Naptha for removing oil
Post by kiwigeo » Fri Oct 12, 2007 10:53 am
Okay Ive got a French Polish job here thats turning nasty on me. The shellac surface has a few minute breaks appearing in it. Its not an issue with shellac or the oil itself..both have been changed. The most likely culprit is some olive oil that has somehow gotten into the rosewood pores..possibly during sanding back (might have got to bare wood in a few places).
Ive removed the shellac and sanded back the wood and now I want to clean out any residual oil from rosewood pores. The OLFers reccomend naptha for this. Anyone know where Id get some here in Australia (preferably Adelaide).
TIA Martin
Paul B
Post by Paul B » Fri Oct 12, 2007 11:16 am
Mitre 10.
Ain't called Naptha here though. Here it's call shellite. Cost you about 8 or 9 bucks for a liter.
Post by kiwigeo » Fri Oct 12, 2007 11:18 am
Thanks Paul
I asked the people at local Mitre 10 and they didnt have a clue what I was on about.
Cheers Martin
Paul B
Post by Paul B » Fri Oct 12, 2007 11:21 am
Yeah I get that a lot at mitre 10. Blank stares.
Bunnies will have it too. As will a well stocked Shell servo, it ain't called 'Shell'ite for nothing.
Ron Wisdom
Post by Ron Wisdom » Fri Oct 12, 2007 12:45 pm
I think naphtha is the same thing as lighter fluid.
Ron
Post by kiwigeo » Fri Oct 12, 2007 1:19 pm
Okay I got my hands on some...lets see if it helps with my problems.
Post by Craig » Fri Oct 12, 2007 2:19 pm
G'day Martin, Next time leave the oil out altogether. I don't use any when french polishing . It may take a bit longer , but you'll have less problems . If you do use it , you have to really ensure you raise it all to the surface with alchohol sessions and wipe it off with a soft cloth. If it is left in , it will cause cracking , and later on , the finish will turn very dark. I've seen some American pianos turn black, like tar. It's quite common.
Users browsing this forum: No registered users and 98 guests
