12 string update pics
Joel,
The Stewmac intonator is great, although on the 12 string you can only do 6 strings at a time and as you can see from the pics I couldnt get the intonator to fit around the end pin so had to use a piece of string instead.
I used the intonator on a recent saddle re-route on a friends 6 string and it worked a treat. Its a very useful loittle tool.
Cheers Martin
Cheers Martin
That is one fine looking instrument you have going on there Martin. I know we all mess about a fair bit here at the ANZLF, but I must take a moment to step back from my usual denigrations and say, as a Luthier my friend, you certainly are going forward in leaps and bounds.
Well done mate, very tight
Thanks Kim,
Lets just hold off the accolades until the thing is fully strung up and singing. This guitar like all before it has been a learning experience and there are quite a few things id do differently next time around. One thing I discovered today was that the tuner placement wasnt quite spot on to allow strings 2 and 11 to clear tuners for strings 1 and 12. Next time Ill do a full scale drawing of nut and headstock to get it perfect.
Im 6 bridge pins short so a full string up will have to wait till next week when spares arrive.
Cheers Martin
Cheers Martin
Okay I finally got the compensation sorted. In case anyone is interested results were as follows:
String (guage) -compensation
1 (0.010") - +3.5mm
2 (0.010") - +3.5mm
3 (0.014") - +6.0mm <== not a mistake
4 (0.014") - +6.5mm
5 (0.023") - +3.5mm
6 (0.008") - +2.5mm
7 (0.030") - +6.0mm
8 (0.012") - +4.5mm
9 (0.039") - +8.0mm
10 (0.018") - +6.0mm
11 (0.047") - +6.0mm
12 (0.027") - +6.5mm
Scale length is 25.3" (643mm).
1 (0.010") - +3.5mm
2 (0.010") - +3.5mm
4 (0.014") - +6.5mm
5 (0.023") - +3.5mm
6 (0.008") - +2.5mm
7 (0.030") - +6.0mm
8 (0.012") - +4.5mm
9 (0.039") - +8.0mm
Martin ,
I agree with Jeff , the figures don't seem right to me at all ! .
I'm trying to think of where you may have gone wrong. Your nut slots pictured earlier look to be way too high to be able to do the intonation correctly. Maybe ,that's part of it ??,, or your tuner ?,, or wolf notes ?, or that 'intonator thing '? It may be a combination of one or all !
12 and 11 can't be right ! , and the A string longer than the E ???? . The high "G" needs to be way forward also .
Take another good look at my notes on your 12 string compensation thread . Did you not read it ???
The saddle positions should look a lot like this :
Also note Alan Carruth's 12 string saddle compensation to be virtually an identical pattern
I'm hoping you haven't already slotted the bridge !
Craig Lawrence
Okay you can stop bldi panicking you guys. I've routed the slot but its a bldi 5.5mm wide saddle so there's heaps of leeway for ridge positon on top of same.
Yes the nut slots are way high. I dont cut them down to final depth until saddle is in. I rough out intonation only to work out where to cut the saddle slot. If I was using a narrower saddle I'd cut the nut slots to final depth before fitting saddle. There is method in my madness.
Jeez youd think I'd just destroyed the guitar....
A useful tool for determining saddle position is the Stewmac fret calculator
http://www.stewmac.com/cgi-bin/hazel.cgi
which gives positions for high and low E
I suspect you are probably 1.5mm too long on all your compensation lengths due to high nut slots and or high strings at the saddle.
No there ain't ! . Not on a fully compensated 12 string. As you can see by my above pic , You'll need the full 5 mm. to have it intonate correctly.kiwigeo wrote:Okay you can stop bldi panicking you guys. I've routed the slot but its a bldi 5.5mm wide saddle so there's heaps of leeway for ridge positon on top of same.
Sorry to see you so upset Martin ,old buddy , old mate
Remember : Everything is repairable !
Cheers Mate
Craig Lawrence
Okay,
Ive got the saddle fitted and have been fiddling with intonation on bass E pair, top E pair and the G octave pairs. All intonate ok with exception of string 11 (low E slightly sharp) which needs to go back a fraction on the saddle and the G octave (string 6) that is right at front of saddle and could move a fraction forward (slightly flat).
The end analysis.....saddle needs to rotate a fraction. Anyway Im going to string up the thing because I cant wait to hear what it sounds like and then do a saddle slot fill and re-route job. Ive already done one of these this week so might as well get good at it.
Just for the record I totally f***ed up the saddle job because I didnt pay attention to Craig's detailed and learned instructions. Ive got big time egg on my face...but the whites will come on handy for my next pore fill job.
Hey Martin, I mentioned to Graham the other day how you seem to have incredible patience. Didn't you re-do the back of one of your guitars 3 times??? I would have ditched it and started again.
So if you only have to do this twice you are miles ahead
Good luck, oh, and read the instructions next time
Root cause is relying on working out intonation myself with nut slots not cut to final depth (= strings too high) and then positioning saddle slot based on same.
Allen wrote:So, what do you think has been the stuff up Martin? String hight?
I'm not trying to rub it in, just hoping not to make the same mistake.
Yeah the Hauser classical has had 3 backs.....french polish problems due to wood contamination and then back lost its arch. I then merrily scraped through the bindings on one side so had to redo same.
I dont know if Im very patient...some of my problems probably have lack of patience as a root cause.
Dominic wrote:Hey Martin, I mentioned to Graham the other day how you seem to have incredible patience. Didn't you re-do the back of one of your guitars 3 times??? I would have ditched it and started again.
So if you only have to do this twice you are miles ahead![]()
Good luck, oh, and read the instructions next time![]()
You and me tokiwigeo wrote: I dont know if Im very patient...some of my problems probably have lack of patience as a root cause.
Martin do tell, could the "contaminated" back set you replaced have been an opportunity grade set of EIR from Luthiers Mercantile by any chance??? I would be VERY interested to know.
I think it was. From a different batch from the stuff they recently had on special. I got this stuff about 3 years ago and I've used it on other guitars with no problems.Kim wrote:You and me tokiwigeo wrote: I dont know if Im very patient...some of my problems probably have lack of patience as a root cause.![]()
Cheers Martin
The set I have used came from the $10 per set deal from LM about 3 years ago as well. For the life of me I cannot explain the ridiculous fisheye I am now confronted with. I am talking nearly 5 cent piece sized fisheye in neat Zpoxy! I have washed with shellite 3 or 4 times, clean rag each time then sanded back to bare wood, washed again and still more fisheye, much smaller but it is therekiwigeo wrote:I think it was. From a different batch from the stuff they recently had on special. I got this stuff about 3 years ago and I've used it on other guitars with no problems.Kim wrote:You and me tokiwigeo wrote: I dont know if Im very patient...some of my problems probably have lack of patience as a root cause.![]()
Cheers Martin
Not very cheery
I pretty much went through the same process....sanded back and washed with Shellite. Didnt help at all. Thought it was the shellac so changed that out but still same result. Surface was breaking up after a day or two.....I wouldnt call them fish eyes....looked like hairline cracks at a distance.
Funny thing is the sides were ok but thats not significant as sides and backs werent matched sets.
Is it worth talking to LMI about this? Others may have had similar problems.
Cheers Martin
Cheers Martin
Kim wrote:
The set I have used came from the $10 per set deal from LM about 3 years ago as well. For the life of me I cannot explain the ridiculous fisheye I am now confronted with. I am talking nearly 5 cent piece sized fisheye in neat Zpoxy! I have washed with shellite 3 or 4 times, clean rag each time then sanded back to bare wood, washed again and still more fisheye, much smaller but it is thereWhen I look close, it really does look like something IN the wood.
Not very cheery
