New Tips du Jour video up today
- ANZLF Approved Supplier
The newest tips du jour video is up today. This one is about using a drill press as a router.
Enjoy!
youtu.be/
Enjoy!
youtu.be/
www.obrienguitars.com
- sebastiaan56
- matthew
Robbie, (or anyone!) ... how the hell do you stop the chuck from falling out of the morse socket?
Using the drill as a router like that is a great trick, but as soon as it starts nibbling the wood, the vibration shakes the chuck out. I've cleaned the taper really well and tapped it home. It stays in fine until I start cutting.
Matthew
Matthew
My drill press doesn't have a Morse taper chuck. It screws on, reverse thread. My lathe has aj Morse taper.
Waddy
Matthew ,
My drill press had develped a little play . I regreased the outer shank (don't know what the technical term is for it , but the shank that goes up and down dissapearing into the body of the machine ) as well as the height gearing strip. Wind the chuck down to it's lowest point and whack in some grease into the top pulley shaft hole too. My grease gun hose just fitted in. By doing this I found I had taken out all the play in the machine by greasing alone. Well ,, until it needs regreasing once again in the future
My bearings are still fine, despite stories I hear of using a drum sander wearing out the bearing, although I'd love an oscillating spindle sander to curb that fear and give a better finish.
Apologies if this info is old news to you . Probably belongs to drillpress basics ,and everyone knows about it anyway !
Craig Lawrence
Matthew,
This is a common problem. Whenever I have my sanding drum in the chuck eventually the whole thing falls out. Not sure on the long term cure for this..I just put up with it. My drill press is a Carbatec.
Cheers Martin
Cheers Martin
matthew wrote:Robbie, (or anyone!) ... how the hell do you stop the chuck from falling out of the morse socket?
Matthew
