Bridges..How to?
gratay
Post by gratay » Tue Sep 09, 2008 12:34 pm
thanks guys ..
Graham that sounds like what I've been reading..
so basically prior to fretting if i lay a straight edge on the fingerboard it should sit right on top of the bridge. Does this sound right
(given that the medium frets I'm using are about 1.1mm in height) ...
then once fretted should get the right clearance.
sounds like i will have to make my bridge thickness around 7.7/7.8mm ..Sounds like that maybe right on the borderline of bridge thickness .
thanks guys,
Grant
Post by Allen » Tue Sep 09, 2008 5:35 pm
Good stuff to read here. It's amazing how a simple question can bring out all kinds of little bits of info that's useful that I didn't know before.
Dave White
Post by Dave White » Tue Sep 09, 2008 6:56 pm
Grant,
Around 8mm or a tad over and I think you will be fine. You need the straight edge to be slightly higher than the top of the bridge (like Graham said) to allow for the string pull on the neck. With your 7.7mm plus 1.1mm fret height the extra 0.8mm should allow for this and bring the straight edge close to the top of the bridge. Then your saddle height above the bridge is determined by the action in the centre of the fretboard. If you want a low action, say 4/64" (1.59mm) then your saddle will be 8/64"(3.19mm) above the top of the bridge, and your strings will be 28/64" (11.19mm) above the top of the soundboard at the bridge. If you want a high action, say 6/64" (2.38mm) then your saddle will be 12/64"(4.76mm) above the top of the bridge, and your strings will be 32/64" (12.76mm) above the top of the soundboard at the bridge.
Dave White
graham mcdonald
Post by graham mcdonald » Tue Sep 09, 2008 7:26 pm
I have always done it with the frets in, but I make my necks in a funny way anyway, so I can alter the neck angle to the bridge height of around 10mm. Getting the neck angle right is always hard. If you have a perfectly flat soundboard it is fairly simple, but very few soundboards are, or should be for that matter. It gets even more complicated with a spherically domed soundboard (which is quite fashionable at the moment) where the neck has to be set at a tangent to the surface of the imaginary sphere that the soundboard is but a little segment of. Even when the arch of the soundboard that is set with the X braces shaped to the common 24' radius, that still puts a rise of between 1-2mm at the bridge if the soundboard is glued to to the sides when the top of the sides are in a plane. That means the neck has to be kicked back a little for the line along the top of the frets to be 10mm or so above the soundboard at the bridge.
There are several ways to work out this geometry. Jim Williams book, where he builds the body on the solera/workboard from the soundboard up, shows a good way for a beginner to do it. Jim's book builds the neck in at the same time, in the manner of the Spanish classical builders, but a bolt-on neck is a much better solution (and Jim does that himself these days). Still the making the body face down workboard is a effective way of being able to establish the neck angle once the soundboard, sides and blocks are all together.
There is no 'right' way to do this, just several methodologies which end up with the same result. The 10mm thick bridge allows enough depth in the saddle slot for 5-6mm of the saddle to sit solidly in there so it won't flop around with 3mm above the bridge top which you do need for the break angle over the saddle. There is also enough room to fit an undersaddle pickup if that is needed (but I hate the things and think they should all be thrown into a lake of boiling lava) (the one just down the river from the Skull Cave)
graham
Graham McDonald
gratay
Post by gratay » Wed Sep 10, 2008 11:57 am
Thanks Dave, You've saved my little brain all the maths..I will digest this post a lot more as i get closer.
and Graham I am with you on the piezo sound ...I detest it so much and under no circumstances will an undersaddle pickup be going anywhere near this guitar.... I may try a K & K though.
which leads me to a question,,
If there is no need for an undersaddle arrangement what depth of saddle slot can you get away with?
cheers Grant.
Post by kiwigeo » Wed Sep 10, 2008 12:09 pm
I generally rout my saddle slot to at least 5-6mm. My general rule is to have slightly more of the saddle in the slot than sitting above same.
Post by kiwigeo » Sat Sep 13, 2008 7:54 pm
I received my Stewmac Intonator today along with a pile of wood from Tim Spittle.
Anyway I put the intonator to work on an Ibanez hack guitar my friend wanted me to change from right to left hander. The gadget is brilliant....took about 45 minutes to get it fitted and the new saddle slot pencilled out. The bottom E string needed a good 6mm compensation and could probably go back another 1mm if there was room. The guitar was obviously poorly setup when it came out of the factory.
Anyway if you want to make intonation an easy job then get one of thse babies.
Nick Payne
Post by Nick Payne » Sun Sep 14, 2008 7:36 am
This article is worth reading:
http://www.newmillguitar.com/millen2.htm
It exclusively deals with compensation on classical guitar though.
Post by kiwigeo » Sun Sep 14, 2008 10:09 am
Interesting article Nick......but I wasnt filled with confidence when I viewed the title of the article "A well Compansated Guitar". I was also puzzled by the author's use of the word "lutherists".
Cheers Martin
graham mcdonald
Post by graham mcdonald » Mon Sep 15, 2008 7:39 am
Compensation at the nut has become quite fashionable in recent years and probably does add some extra control to the process, but all this stuff ignores the fact that the frets are positioned to an average position a 'well tempered' scale and so no fretted instrument can ever play exactly in tune.
graham
Graham McDonald
gratay
Post by gratay » Sun Oct 12, 2008 10:01 pm
Sorry to drag this thread up again but..
I'm getting cold feet about routing the saddle slot when the bridge is glued on...
Making a simple jig to do it is no problem,... but I'm wondering how you guys get the slot started. I'm assuming you don't just try and place a spinning router bit accurately onto the jig?
Do you have the router sitting in the jig ,start it up and somehow lower the cutter until it touches the bridge lock it off and make a pass..
Or do you use the radius of the bridge and set it up so that the cutter just touches the bridge at the highest point in the middle....make a pass and gradually lower it..
Its got me wonderin'?
Cheers Grant.
Dave White
Post by Dave White » Sun Oct 12, 2008 11:33 pm
Grant,
The ideal way is to use a plunge router. I route the saddle slot first in the thicknessed bridge blank and then do all of the bridge shaping after this.
Dave White
Rod True
Siberian Tiger
Post by Rod True » Mon Oct 13, 2008 2:22 am
Grant I slot my bridges before gluing it to the body.
Here's a couple pictures of my jig
I use the wedge to secure the bridge in place. I turn my router on, lean one corner into the stoped edges (lower left) lower the router into the bridge till it's sitting on the jig, then I just route the slot.
I don't believe that it's more accurate to route the slot on the bridge after gluing to the body. It's all just about measuring properly. And if you're able to make some locator jigs, it can be faster to attach a fully finished bridge and go right to fine tuning the saddle instead of messing around with an intonator and jig to possibly scuff up a nicly buffed body.
Oh, and all my jigs are glued together with Fish glue which gives them better transfer of energy vs titebond or other PVA or AR glues :lol:
gratay
Post by gratay » Mon Oct 13, 2008 8:26 pm
Dave, why didn't I think of that..of course ..plunge router..
I was so fixated on how to do it with my laminate trimmer. :oops:
thanks.
Rod , thanks for a peek at your jig. good point about unnessesary fiddling around with the guitar after the finish has been applied.
Post by Kim » Mon Oct 13, 2008 9:18 pm
Rod True wrote: Oh, and all my jigs are glued together with Fish glue which gives them better transfer of energy vs titebond or other PVA or AR glues :lol:
Your a shit stirrer Rod, that's probably why you fit in so well here. :lol: :lol: :lol:
Rod True
Siberian Tiger
Post by Rod True » Tue Oct 14, 2008 3:54 am
Just exercising my honorary Australianhood :gui
Post by Hesh1956 » Wed Oct 15, 2008 11:36 am
If when you position a pre-slotted saddle by referencing the saddle at the proper position great intonation is completely possible without routing the saddle slot after the bridge is installed. I have never done it any other way.
I agree though that routing the slot after the bridge is installed, and installed in the correct location, is a sure bet provided that the extra risk of this operation does not bite you.
I also prefer a 1/8" wide saddle just in case I need a bit more adjustment.
Here are some examples and if you look close you can see that where my intonation needed to be was well within the range of saddle crowning adjustment available to me. All these bridges where glued on with pre-routed saddles slots. BTW only one of these bridges was a CNC copy of an original design - can you guess which one?
gratay
Post by gratay » Thu Oct 16, 2008 2:22 pm
Lovely looking bridges Hesh...I can't pick the CNC one.
A question for those that use the IBEX ruler to locate their bridge...
It has a marking for the E string with compensation added..
I'm wondering would this be for the front edge of the saddle slot or the middle of the saddle slot?
does anyone know?
cheers Grant.
Rod True
Siberian Tiger
Post by Rod True » Thu Oct 16, 2008 3:18 pm
Good question Grant. Now I don't know these rulers and I looked on the Guitar Woods website and it didn't say.
Most compensation is designated to the center of the saddle, not the leading edge so that would be my guess, but it's just a guess.
Rod True
Siberian Tiger
Post by Rod True » Thu Oct 16, 2008 3:19 pm
Hesh, those are nice looking bridges. My guess is they are all CNC because you're such a tool :bum
graham mcdonald
Post by graham mcdonald » Thu Oct 16, 2008 3:31 pm
does anyone know?
It doesn't really matter where on the saddle you make that point. I place it 1mm or so from the front edge to give a little room for adjustment, which also gives a little more saddle to play with for the bottom string.
graham
Graham McDonald
Users browsing this forum: Google and 109 guests
