Kim, do you have the wood sandwiched between two slats? In your original post I think you had the wood then the blanket and then a slat. Looks to me like a bit of support on the outside of those bouts might help you.
My stack up is as follows:
stainless steel slat - wood wrapped in foil (spritzed with water), stainless steel slat - blanket - spring steel slat.
I have the blanket on while Im bending and turn it off as soon as everything is clamped down. I wait about 4-5 hours and then give it another 3 minute burst before leaving overnight still clamped up in the bender.
First Day in Shop for Six Months - Disaster Struck
- Kim Strode
Thanks Martin,
I do have stainless steel sheets top and bottom, but blanket directly in contact with wrapped side. I haven't had blanket on for that long as I'm concerned about temperature, after burning first side.
It takes 2.45 minutes for blanket to reach 158º C, then I turn it off and begin bending. I start by winding down centre caul, then bend over large bout.
I then turned on blanket for 1 minute and started bending small bout nearest the neck. I achieve this by clamping shaped caul downwards over last curve where body meets neck. This is the bend that is hardest to achieve.
Kim Strode
Daylesford, Australia
It looks like there is a fair bit of figure and runout in that side Kim. This is going to make it a bit tricky to bend, but you know, thinning the side down to the around 2.3 mm is going to make a huge difference in how easily they bend compared to 2.7 mm.
This side doesn't looked scorched at all either, which means that you've got the moisture trapped in the al-foil packet while you've got the heat on and are bending. A really big improvement on that first go. :serg
