Wanted- Bending Iron
josh_cain
Post by josh_cain » Tue Nov 04, 2008 9:16 pm
Hi guys,
I'm not sure if I'm allowed to do this, so sorry if I'm not.
BUT....
Im after a bending iron.
If anyone has one they want to sell please let me know!
cheer
josh
Josh.
Post by kiwigeo » Tue Nov 04, 2008 9:38 pm
It's ok by me.....
Post by Taffy Evans » Tue Nov 04, 2008 10:12 pm
Hi Josh
If you can't buy one, heres some pictures of two of mine, easy to make if you get the parts. I've had these for over 30 years and they work fine.
The pipe is whatever I could get, one is brass or bronze pipe ?? about 5mm thick the other is also brass but poss 2.5 mm thick. Both have a 1000watt radiator element in them held with the porcelain heater fittings. They are both wired through a variable oven thermostat control.
Oh, the safety features were removed for clarity....... do you believe that, you have to be carefull with this model.
Others have used a gas burner aimed up a pipe.
Good luck
James Mc
Post by James Mc » Wed Nov 05, 2008 10:51 am
Hi Josh
I don’t have a camera at the moment but mine is more primitive than Taffy’s. Just a chunk of steel pipe found at a building site, it is wired to a couple of bricks then wired through the bricks to the bench. Heating is by metho from a couple of tin cans cut in half longways with some sand and volcanic rock in them (they sit inside the pipe on a couple of bits of foldd fire blanket). Does the job and cost nothing.
P.S. I have a bunch of extra bone nuts and saddles, PM me your address and I’ll send you a set. I also have an extra set of full size plans for a classical guitar you're welcome to have if they are of any use to you.
James
Post by kiwigeo » Wed Nov 05, 2008 12:07 pm
Taff asked the fire brigade to park their engine around the corner :wink:
Post by Dominic » Wed Nov 05, 2008 1:05 pm
And the Ambos in case of electrocution :?
Hippety Hop
Post by Hippety Hop » Wed Nov 05, 2008 5:14 pm
I'm calling the bomb squad
Post by Allen » Wed Nov 05, 2008 5:52 pm
I love Taffy's bender. It totally validates all the great tips he has. If he was just some dumb ass, he'd of killed himself years ago with that bender. :lol: :lol: :lol:
Post by Taffy Evans » Wed Nov 05, 2008 10:35 pm
My grandaughter used these to bend her dulcimer and mandolin sides, when she was 10 and I honestly did not consider them dangerous. When they are on there hot, a good reason not to touch anything other than wood.
Post by Allen » Thu Nov 06, 2008 6:42 am
Taffy, I wish I had seen your set up before I dropped $250 on my electric bender. Our recycling shop has heaps of old ovens and hot plates for the taking. I had only seen the home made jobs with the butane torch, and I didn't go that route, because I was afraid that I'd always be running out of fuel just when I was in the middle of a bending operation.
