Digital isn't always better
Post by Lillian » Mon Dec 08, 2008 7:27 am
I bought a Caliber III to monitor the RH in my shop. It had good reviews and the price was right. I needed a clock so I grabbed a cheap wall clock with thermometer and hygrometer. I figured it would take a day or so for it to settle in. Well, after a week of 13-15 points difference, I decided that I needed a better analog hygrometer. So I found one that reports to use a hair. Within few hours the two analogs where within 3 points of each other, leaving the digital way below. After reading that some hygrometer are only accurate within a certain range, I decided to bring the shop's RH down to about 50% according to the analogs, hoping that the three would get closer. Nope, the digital was still way lower. Life got busy and I left the shop sitting at the analog's 50%. I watched as the top and back I had joined curl and then flatten after flipping them. It stopped after two days.
Enters JJ's post on making a sling psychrometer. The two thermometers arrived from 4physics.com yesterday. The analogs are basically correct. The sling psychrometer split the difference between the two.
For $13 and two pieces of tape, I have piece of mind and can start gluing.
Thank you JJ for taking the time to post.
Post by Craig » Mon Dec 08, 2008 8:10 am
G'day Lillian,
I have a digital ( StewMac ) and don't trust it either. It's proven to be incorrect too many times .
Here is one I made from 6 strands of my daughter's hair ( 9 " long ) It works on the same principle as the most sensitive ( and expensive ) hygrometers available .
Human hair is the most reliable medium known to man for measuring humidity.
This little unit , although rough around the edges , has proven to be the best and most reliable of all
Craig Lawrence
Post by Lillian » Mon Dec 08, 2008 8:18 am
I've admired your ingenuity for a long time. I thought about making one like yours, but didn't believe that I would be able to make one that was accurate.
Paul B
Post by Paul B » Mon Dec 08, 2008 9:15 am
No inlay?
Post by Craig » Mon Dec 08, 2008 9:25 am
Lillian wrote:I've admired your ingenuity for a long time. I thought about making one like yours, but didn't believe that I would be able to make one that was accurate.
It's the hair that's accurate Lillian ,,,, not me ! :lol:
Here's a link to the Franklin institute on how to make one.
http://sln.fi.edu/weather/todo/hygrometer.html
I tied the end of the hair strands to an eye hook at the top of the guage . This way ,I could make an adjustment to the hair length by winding up the strands until I have it calibrated
No inlay Paul :lol: Getting slack huh ?
Craig Lawrence
Post by Lillian » Mon Dec 08, 2008 12:20 pm
Craig, how did you calibrate it?
Post by Taffy Evans » Mon Dec 08, 2008 12:53 pm
Hi Lillian
Iv'e got the Stumac digital and an old anolog version. The other week it was so dry it stopped displaying, just a row of dashes. I got a bucket of water and a fan blowing across it and found that when the MC of the room got to 15% [according to the digital device] it started recording again. On another occaison the humiditay was reported as 90% plus for our town but the reading was about 80%. So I'm going to hit up the grandkids for some hair.
Post by Lillian » Mon Dec 08, 2008 1:13 pm
Fran's hair is definitely long enough, and she leaves them around the house, so I don't have to sneak up with scissors. It's the calibration that's got me, especially the low end of things.
Now that I have the sling psychometer, it isn't a big deal.
ap404
Post by ap404 » Mon Dec 08, 2008 3:29 pm
Brilliant Craig,
Well, I'm going to have to try this but i'm bald as and my lady friend has corkscrew hair ( notoriously sensitive to weather ). I wonder if the curls will interfere with the readings ?? :)
I might have to go for 10c of ballast instead of 5 ...
i got a hot rod ford and a two dollar bill, and i know a place right over the hill ...
www.flickr.com/photos/harvesterworks
Post by Craig » Mon Dec 08, 2008 6:39 pm
Lillian wrote:Craig, how did you calibrate it?
That's the tricky part I suppose, but here's how I went about it.
Soak the hair in water. This gives one extreme . Mark that spot. Now dry it completely with a hair dryer . This will give you the other extreme. Mark that spot also.
Measure the midway point between these two marks . Call this 50 %
From there , I fine tuned it over a period of time by comparing with radio weather reports and other hygrometers etc . I now have it to a stage where it's about right. I've become very fond of it ! :lol:
Seeing as you have a sling psychrometer Lillian , I'd compare it to that for a start.
In my opinion I don't think it necessary to build to an exact number such as 43% ,,,,,,,or 44 % or whatever . I'm happy if it's between 40 to 50 %.
Instruments will go through all sorts drastic humidity changes during it's lifetime . If it's built within this midway range , I'm sure it will cope . All those early master builders never had a digital read-out.
Craig Lawrence
Users browsing this forum: No registered users and 130 guests
