Measurements On Dark Woods
- ozziebluesman
Just finished a Ukulele fingerboard made from Indian Rosewood and while cutting the slots I missed a marked measurement by a mm. Damm!!! It is on the 18th fret so I am not too concerned. Except I know it's a mistake and I hate that!
So what do you all use to mark out darker woods to make it easier to see the measurements? Pencil is just too hard to see unless you have exceptionally good light!
For marking out fretboard slots I use wfret to print a paper template, check the distance to the 12th fret (for printer error) and adjust scale input if needed
I then lightly glue it to the centre of the fretboard, mark through the paper into the board with an awl and pull off the paper.
I cut with a handsaw in a mitrebox and find that the awlmark is great to line up the saw on. Chalk like Lillian suggests would be great.
- sebastiaan56
I've got your disease too Alan. I will use a white pencil to mark the spacing. Double check. It's dead easy to get the spacing wrong, so I find that marking them out with the white pencil and then standing back for a look will show if something is off very quickly.
Then I scribe the line with a sharp scalpel and rub in some chalk.
- ozziebluesman
Users browsing this forum: nkforster and 65 guests
