New Luthier Tips du Jour video - Cutting Binding Channels
Robbie O'Brien
ANZLF Approved Supplier
Post by Robbie O'Brien » Mon Jan 05, 2009 3:43 pm
Here is the newest Luthier Tips du Jour video. Topic is Cutting binding channels.
As always, discussion and comments are welcome.
Enjoy!
youtu.be/
www.obrienguitars.com
Post by Allen » Mon Jan 05, 2009 6:43 pm
Wish I had seen that when I was first starting out Robbie. Would have saves a lot of anxiety.
Do you bother with using a gramil to score the top before you route the channels? I haven't yet, but occasionally get some chip out that I end up having to try and camouflage, so have a gramil on order, hopping this will fix the problem
Post by Kim » Mon Jan 05, 2009 11:03 pm
Thanks Robbie,
These vids are great. Rather than just showing one way to do a task, they make people aware of all the options leaving the door open wide for those new to the craft to choose what they feel most comfortable with. Well Done.
Robbie O'Brien
Post by Robbie O'Brien » Tue Jan 06, 2009 12:44 am
Allen wrote:Wish I had seen that when I was first starting out Robbie. Would have saves a lot of anxiety.
I used to always use gramil for scoring the top. Then one day I couldn't find it. How many times has that happened to us in our shops? :lol: I had to proceed without it and nowadays that is the way I do it.
John Maddison
Post by John Maddison » Fri Jan 09, 2009 12:15 pm
Another gr8 tute Robbie!
Where did you score that tilting base for your laminate trimmer? ... great idea!! is it only available for a particular model of trimmer, or is it a universal attachment? or is it a home-built job? Any change of a couple of close-up pics of it?
cheers & thanks
John M
Robbie O'Brien
Post by Robbie O'Brien » Fri Jan 09, 2009 3:30 pm
John,
most of your major laminate trimmer brands make a tilt base for their trimmers. It is usually cheaper to buy the laminate trimmer kit that comes with a couple of bases and some accessories than to buy the trimmer and base seperately.
Drjay
Re: Routing Binding channels
Post by Drjay » Wed Jan 14, 2009 11:29 pm
Hi
Is there anywhere in Australia where I can buy routing cutter bearings? If yes what range of sizes do you recommend?
Ciao
Post by kiwigeo » Thu Jan 15, 2009 12:51 am
Drjay wrote:Hi
Ciao
Carbitool have a few bearings but you wont get a range of sizes like you do with the LMI/Stewmac kits.
Post by Allen » Thu Jan 15, 2009 6:55 am
Getting the right bearing size is pretty important in getting the bindings to fit without a lot of extra work. I looked everywhere I could think of locally to get them, but the sizes were fairly limited. In the end I went with the LMI ones.
