truss rod length
- cactus bum
truss rod length
Howdy folks, I am deciding on the length of truss rod for my size 5 with a 14 fret to body neck. The scale length is 22.75". From nut to body is 12.616". My head block is 1.5" deep. This means a distance of 14.116" from nut thru the head block.
I spoke to the Stu Mac techie and he said I could begin the routed channel between the first and second frets. This would mean a distance of 12.239" from middle of first and second frets thru the head block.
My truss rod length options are 12", 13.25", and 14.5" from LMI. Stu Mac offers 12.25, and 14.25" I want to use a 2-way adjustable truss rod.
The 14.25" rod from Stu Mac would barely peek out of the head block slot if I routed the channel from the nut thru the head block. The 12.25" rod from Stu Mac would barely peek out of the slot in the head block if I routed the channel from between the first and second fret thru the head block.
I am making a one piece laminated neck of mahogany. I have heard one piece necks are liable to break at the short grain area where the neck meets the head stock. I don't want to do a scarf joint for strength as I will be playing this guitar and not a 12 year old. Will routing the channel from the nut mean the nut area will be further strength compromized and be more likely to break eventually? By the way, I also think I will be using a couple of carbon fiber strip1/8" X 1/2" on either side of the rod, ala Allen.
If anyone wants to tell me which length truss rod to use you win a small worthless prize, like at the carnival, and will have my lasting gratitude. Cheers, Cactus
Michael Pollard, but you can call me Cactus
Not a direct answer Cactus, but some folks have had quality problems with the stewmac hot rod.
Many have gone over to the allied rod, we had a grup buy here afew months ago.
I was impressed with the rods I got and bought more for an electric and a bass project I am working on.
With the allied rod, the adjustment nut is very small so you can do headstock adjustment without losing too much material like with a gibson style nut
- cactus bum
- graham mcdonald
Alternatively, you can make your own rod. Both Jim Williams and Cumpiano/Natleson have good directions for making a double rod, and you can make them any length you want. It is very simple and pretty foolproof and you don't have to make any compromises in the length. LMI sells allen key nuts for them which are little more than 1/4" across, so even with a nut end adjustment, you don'y have to take too much wood out.
graham
graham
Graham McDonald
The great thing about the Allied-style rod designed by the wonderful luthier Mark Blanchard, is that it uses differential screw threads rather than opposing, left/right threads. The differential threads give you what amounts to a geared down effect so less torque on the rod (and more turns) is needed to bring the neck into compliance with what you want. It's a brilliant design. I buy 'em, I use 'em.
Rick Turner
www.renaissanceguitars.com
www.d-tar.com
www.d-tar.com
- cactus bum
Thank you all for your input. I will go with the Allied rod. It looks like a hum dinger.
After posting my question in this post I read it again and lo and behold I saw my answer. With whatever rod length I use I now see I can rout out the channel from whereever it needs to begin at the upper part of the neck. If the rod doesn't peek out of the head block enough I obviously need to start the channel farther down the neck. What I still don't know is if there is anything wrong with the rod going from the middle of the first and second frets, or must it begin closer to the nut?
Being a novice in a field is humbling. The most basic concept in lutherie is a new mountain for me to climb. Thanks again for everyone's time. Cactus
Users browsing this forum: Google and 121 guests
