Behind is the new Dick glue pot that arrived today. I used it on the last rib and I cant say its much better than the leg wax warmer.
Oh Oh, another rainforest near extinction somewhere on the planetkiwigeo wrote:Anyway the island workbench has been taken over by huge pile of tonewood that came in the other day and I cant be bothered moving it out of the way.
G'day Allen, Just got my baby's bottle warmer as well. Paid a little more on e-bay. Caused quite a stir with my friends... cheers, RobertAllen wrote:Once you get onto using Hide Glue, you'll wonder why you waited do long. I'm using the baby bottle warmer as well, and I can't fault it. Especially for the $5 is cost from Vinnie's.
Looking forward to seeing a few ribs going on.
Hello Kim, Just got my bottle warmer.. very fancy. What temperature do you use? I'm new to this, making a Baroque Lute so any help would be appreciated. Cheers, RobertKim wrote:The Avanti baby bottle warmers are THE best glue pot on the market. I fooled around with a thermometer and the thermostat control until I got it spot on. I then marked the plastic body of the unit with a hot pin. Now if I knock the control knob I just turn it back to my pin point and it's spot on, the accuracy is brilliant but then it would need to be, after all it is made to heat baby food, imagine the law suits if they were bunky.
Hi Robert,zendo wrote: Hello Kim, Just got my bottle warmer.. very fancy. What temperature do you use? I'm new to this, making a Baroque Lute so any help would be appreciated. Cheers, Robert
Nice tip Martinkiwigeo wrote:Another tip. I make up a batch of glue and then pour it into an ice cube tray and let it set. I then store the blocks of hide glue in the fridge until I need them. One cube generally is enough to do a couple of ribs. I put the cube into a small plastic youghurt it and sit that in the water bath. When the glue job is finished I either chuck the tub away or if theres enough left for another job I put it in the fridge.
Cheers Martin
Step 2- Extract rolling pin from backside just after wife finds out you've been using her kitchen equipment in your workshopmatthew wrote:Go get the electric spice grinder from the kitchen.
Thanks for yet another tip. I looked up the Andrew's glue notes and they will help when I'm at that stage. I have some left over Rabbit Skin Glue from my painting work. I use it sometimes to coat the canvas on a stretcher before applying the undercoat oil paint. Would this glue be suitable? If not I noticed Carbatec had some packets of hide glue. I suppose you are keen to get back to it. Cheers, Robertkiwigeo wrote:Hi Robert,
Van Andrews has a section on hide glue at the end of the Renaissance lute tute CD. It should be on the Baroque lute CD as well. If you dont have it let me know and Ill send you a PDF when I get back home (in about two weeks).
Ive been using a temp of around 65-70degC for my glue jobs. I also run a heat gun running on low heat over my joints before glue up to warm up the wood a bit. The glue Im using is the pearl hide glue available from Ubeaut (I think Carbatec stock it)..Im not sure what strength it is but it seems to work ok. Just watch you dont undo any previously glued joints with the gun. Van Andrews instructs to use sellotape for temporarily holding things together...Ive gone to using LMI binding tape as a substitute....its stronger than sellotape and easier to get off. I alaso use map pins in place of the little wooden stops he uses to stop the ribs slipping around the mold.
Cheers Martin
Users browsing this forum: Google and 111 guests
