Good one Hesh.
Hello Martin, So you are back with us.... and back to the lute in time hey... Robert, still at it....kiwigeo wrote:Lilian..youre very naughty.
Feeling a bit better today but could have done without the hot water system blowing up. While helping the plumber cart the new cylinder up the path the bldi rubber hand gribs on the sack trolley came off in my hands and the cylinder came crashing down on top of me. I escaped with bruising on both ankles but it could have been alot worse.
Hot water back on line and its time for a long hot shower and NO Kim and Hesh youre not invited!)
Nick O wrote:Good thinking that mankiwigeo wrote:Nick, glue buildup on the outside of the body isnt as bad as on the inside. I work with a fleet of 6 scrapers so Im always working with a sharp one.
Always keep a few for just such a casekiwigeo wrote:The same sound planning applies with sheep.....always have a few spares waiting out in the pen in case you wear your date out.
matthew wrote:I have questions:
Why aren't the ribs glued to the tailblock whilst still in the mold, as they are to the neck block?
Violin makers use SOAP as a release agent at the sides of the mold because it doesn't interfere with glueing later on. I have not had much luck with wax of any sort. Soap is way better.
kiwigeo wrote:Matthew,
There is not tail block on this lute. Alot of lutes dont appear to have tail blocks.....I believe its because it would intefer with acoustics of the top. Its the same reason linings arent common on lutes.
Soap could be used on the mould I guess...I just had the paste wax handy. There is nothing that gets glued to the inside surface of the lute body so its not a huge issue.
Cheers Martin
Hello Martin
You are right I believe. The tail block would have an effect on the sound. A Lute is much quieter than a classical guitar. Torres designed his to attempt to fill the larger concert hall. Filling larger spaces was also a problem for harpsichords, clavichords and the like - so the piano was invented.... your lute is looking so good.. are you going to sell it and/or make another? What about a baroque Lute as well? cheers, Robertmatthew wrote:I have questions:
Users browsing this forum: Mr K and 46 guests
