Dovetail neck join
- John Steele
Dovetail neck join
This is how I go about joining a neck and body. I use a basic dovetail joint created with a router, dovetail bit, and jigs. The jigs I use are based on the Don Teeter’s jigs from his 2nd book from a while back. I use the 5/8â€
George Bernard Shaw
George Bernard Shaw
- Hippety Hop
- John Steele
The side angle of the jigs is right at 80 deg. I could Email/post a full size jpg of my jig drawing that fits on a 8 1/2 X 11 sheet. I just glue the print out onto the sheet stock (I use 3/8" ply) & cut/drill.
Yes, racking/rocking to me mean the same. The neck & body lock in and any side or downward pressure does not create any movement.
George Bernard Shaw
George Bernard Shaw
- John Steele
Bob was kind enough to upload the pdf's onto the server. Basically print out full size (no scaling) onto 8.5 X 11 letter size sheet and glue onto sheet stock (I use 3/8") and cut away. Next I add a fence at 90 deg for the female and 91.5 deg on the male. For the male I just joint (rip on saw would work too) the top edge at the 91.5 deg and attach. Here on some more pics to show the finished product.
Male side jig:
The pins you see drop into my truss slot for alignment
Female side jig
If you want to make adjustments for fit, you can cut either the female side opening smaller, or the male side larger. I have used masking tap on the male side to increase its dimensions. I highly recommend cutting some practice joints on scrap stock until you get the fit you want. After that it is all aligning the jigs along a common center line.
Thx Bob
J
Male side jig:
Female side jig
Thx Bob
J
George Bernard Shaw
George Bernard Shaw
- John Steele
duh, the links for the pdfs...
Male: http://www.connor.net.au/malejig.pdf
Female: http://www.connor.net.au/femalejig.pdf
George Bernard Shaw
George Bernard Shaw
- Hippety Hop
Well you got me going.
I reduced to suit soprano and concert ukes. I got my bit from Carbi-tool, where I ran into Max from C&S Saw Blades. Funny, it was them that put me onto him a year or two ago.
The bit cuts a depth of 10mm (3/8"), which is plenty. The bearing is 12.6mm dia., so I'll try making the male jig slot 13 mm wide.
Anyway, cheers and thanks for the plans.
Hip.
Hip.
Hippus Erectus
Hippus Erectus
This is super John! I've been wanting to try the dovetail neck joint and this is just the toot to get me started. I've just used mortice and tenon bolt-on joints so far, but since I seem to be fixated on 12 fret vintage body shapes it just seems I ought to get familiar with dovetails.
Thanks again John for this toot and patterns,
Joe
Joe
