Bolt On Neck Question?
- ozziebluesman
Just wondering what type and size bolts you all use for an acoustic guitar, bolt on neck? I bought some lag screws 1/4" thick and 2" long for my concert guitar build. I feel 2" bolts maybe a little too long.
I would like to know what you all reccomend and where they can be sourced.
- Dennis Leahy
Re: Bolt On Neck Question?
Hi Alan,ozziebluesman wrote:Just wondering what type and size bolts you all use for an acoustic guitar, bolt on neck? I bought some lag screws 1/4" thick and 2" long for my concert guitar build. I feel 2" bolts maybe a little too long.
You mentioned "lag screws", and just want to mention that most bolt-on necks are done with bolts (machine thread) rather than screws (wood thread.) The typical setup uses 1/4-20 furniture bolts like these:
(Furniture bolt into cross dowel.)
And they fasten into the end of the neck (tenon, or the butt end if no tenon is used) into either threaded inserts or "cross dowels" (also call "barrel nuts".) Further, some folks that use the threaded inserts drill up through the neck tenon or up through the guitar heel and glue-in a wood dowel - and that will prevent the threaded insert from going into end grain.
I suspect I'm preaching to the choir, and all you wanted to ask what what length bolt folks are typically are using, but thought I'd throw this out there in case it was helpful.
Another damn Yank!
- ozziebluesman
Hesh: Thanks mate. I have done a little research and it seems this is the most popular hardware to use for a bolt on neck. There is a nice tute by Cumpaino on the net that uses the bolts you speak of.
Dennis: Thanks also. This is my first go at an acoustic neck so I appreciate your extra information.
I think the hardware I bought is a little too long.
The thread was just to seek out what everyone else used.
If the bolts/screws are too long, just cut them down to length and roll the tip a bit to make the threads engage more easily. I cut with an abrasive cutoff wheel either on a grinder or on my table saw. Hold with ViceGrips...or whatever your Aussie equivalent is.
Rick Turner
www.renaissanceguitars.com
www.d-tar.com
www.d-tar.com
Don't think Kim was joking Rick.
I've never liked the idea of putting barrel bolts into the tenon with only end grain holding it in. I've seen a story in the GAL journal where Doolin uses a maple insert with cross grain in the tenon to help support the barrel bolt. This makes more sense to me but I could be over cautious.
I've been using 1/4-20 lag/hanger bolts (screw one end, thread the other) that I screw into a 13mm dowel that runs the full length of the heal and I only use a very short tenon. I have found some nice looking cap bolts/nuts that thread onto the bolts from inside the guitar and look just like nice knock down bolts. Here's a few pics.
- Mike Thomas
You can also cut those screw/ bolts with a interesting little tool. I am trying to remember the name. Ah, I think it is called a hack saw. Of course if the screw or bolts are hardened you might have to use the butt check method but personally I don't like anything that is described as hard or has the word screw in it to come too close to my butt checks.
Cleaver
Cleaver
Oi! don't ewe start 'Gumboots'.Nick O wrote:Might not want to visit Australia thenCleaver wrote:personally I don't like anything that is described as hard or has the word screw in it to come too close to my butt cheeks.
Cleaver![]()
It is well known that Australian blokes have buns of steel that are tighter than a Scotsman's fist and absolutely impenetrable.
Users browsing this forum: No registered users and 173 guests
