Plastic binding scratches
Paul McAskill
Post by Paul McAskill » Mon Nov 08, 2010 11:52 am
I'm building a OOO size rosewood guitar with white plastic binding and end trim, at the moment I am final sanding with 240 grit and have got scratches in the plastic, particularly noticable across the end trim. Does anybody have some advice on getting the plastic to look scratch-free
Paul.
Pete Howlett
Re: Plastic binding scratches
Post by Pete Howlett » Mon Nov 08, 2010 11:54 am
Scrape it back - look at frets.com for Frank Ford's cheap glass scrapers...
Post by kiwigeo » Mon Nov 08, 2010 11:55 am
If youre scraping close to the edge of the top then try and avoid working the scraper across the grain with associated risk of tear out. I scrape with the scraper at an angle to the grain working out towards the binding.
Paul McAskill
Post by Paul McAskill » Mon Nov 08, 2010 11:55 am
Thanks Pete and Kiwigeo, I'll check out frets.com and try some scraping, cheers Paul.
Adrian Cooper
Post by Adrian Cooper » Mon Nov 08, 2010 11:57 am
Hi Paul ,
Good to see you've poked your head in.(we're practably neighbours.)
I've been lurking around for ages.
When I've scraped the bindings from either top & back,I did like kiwigeo, Plus I put some tape over the edge & at the end of the scraper so that one end of the cutting edge is raised & it only makes contact with the binding. I think you want very little hook on the edge. Safety razors & exacto blades work pretty well too.
With the safety razors , you can apply tape over each end & bend the blade slighty so that only the centre does the scraping. -how much bend determines how wide the scraping area.
Sharp edges & a light touch is the go
Adrian
" its never too late to be what you might have been" - George Eliot
