Legend thank you.kiwigeo wrote:Leave the blank at 25mm and work to final thickness when you shape the neck.
Unless you want to use hot hide glue then Titebond I is fine for all your joints. If this is your first build then I'd just keep it simple and use Titebond all round.BBk wrote:
EDIT. P.S. I was going to order some titebond glue this week to get started gluing it up. Any suggestions for a white glue to use for areas that could potentially need to be redone down the track (fretboard, neck joint etc)?
Thanks Martin. I know this is schoolboy stuff for you guys, really appreciate the advice.kiwigeo wrote:Unless you want to use hot hide glue then Titebond I is fine for all your joints. If this is your first build then I'd just keep it simple and use Titebond all round.BBk wrote:
Users browsing this forum: No registered users and 95 guests
