Guitar Design Software
Ben
Post by Ben » Sat Jul 02, 2011 8:56 pm
Hi again,
Does anyone know of any good easy/simple to use software for designing guitars??
Ben
Re: Guitar Design Software
Post by Kim » Sat Jul 02, 2011 9:18 pm
Post by Allen » Sun Jul 03, 2011 7:02 am
Depends on what you are wanting to do with your design. If it's simple 2D design then DraftSight by Solid Works which is free is the best there is, but learning curve is much like AutoCad. A bit steep. It works on both Windoze and Mac.
For 3D design then you start to get a bit more complicated and there are heaps of contenders out there with varying degrees of complexity and cost. For me the hands down best there is by a country mile is SpaceClaim Engineer. Works on Windoze only, but I've got my Mac partitioned with bootcamp and run SpaceClaim on a MacBook Pro with no worries at all.
Post by Trevor Gore » Sun Jul 03, 2011 10:37 pm
It depends what you mean by "Design"! If you're just looking for something that will help you draw outline shapes of guitar bodies, try this:
http://gicl.cs.drexel.edu/people/sevy/l ... tware.html
Scroll down to the Guitar Design application. It works very well and you can even do headstocks and bridges on it too, though it wasn't designed for that.
There's lots of other great stuff on Jon's site if you dig around.
If you want acoustic or structural design for guitars, that's a very different kettle of fish...
brian64
Post by brian64 » Sun Jul 03, 2011 10:49 pm
trevtheshed wrote:It depends what you mean by "Design"! If you're just looking for something that will help you draw outline shapes of guitar bodies, try this:
Unfortunately, it seems that this will only work predictably with pre OSX Macs. When I tried to run the .sea file, I got a message that is is damaged or incomplete, and an "Automator" window opened - not sure what that's about.
Any ideas how to run it on more up to date Mac's?
Brian
www.BrianDyskinGuitars.com
Post by Trevor Gore » Sun Jul 03, 2011 11:07 pm
Sorry, can't help you on that one. I run Windows myself.
Post by kiwigeo » Mon Jul 04, 2011 7:37 pm
brian64 wrote: When I tried to run the .sea file, I got a message that is is damaged or incomplete, and an "Automator" window opened - not sure what that's about.
Files with a .sea suffix need to be decompressed using "Stuffit"......its a Mac compression utility.
http://store.digitalriver.com/store/all ... 9772245680
brian64
Post by brian64 » Tue Jul 05, 2011 1:00 am
Thanks Martin. Unfortunately, it didn't work for me. Got an error message when I tried to decompress with Stuffit expander.
Brian
Post by Trevor Gore » Mon Jul 11, 2011 10:49 pm
If the Mac version of the Jon Sevy software isn't working for you, email Jon direct. He's very help and put the software up there for people to use. If it's not working, he'll likely help you out. He was kind enough to help me out when I had some issues with the Windows version.
Regards,
brian64
Post by brian64 » Tue Jul 12, 2011 9:02 am
Thanks,
I went back to look for his e-mail address and found that I had downloaded the wrong version - I had the legacy mac version, when I should have downloaded the Java application - the Java 1.2 version works fine.
Brian
Brian
