Nintendo.Lillian wrote:Who wrote the script?
Little help
Re: Little help
Re: Little help
You are a brave man. I know some of their programers.
Re: Little help
Re: Little help
Hi Jeremy,
I've only done one guitar a while back and I'm hoping my next is more of a work of art and there are less mistakes.
When I was cutting the centre of the back for the purfilng to cover the join, right at the end the router moved because of a not tight enough clamp! I couldn't believe what I had done. I was beside myself.
However after much thought and no forum like this, to get around it, I tried to make a feature of it. I did the same to the other side and put some of the same timber from the headstock (figured Houn) so it (kind of) looked like it was supposed to be there.
Nothing to stop you putting lengths of abalone or spots up the inside so it takes on a pattern. Never know, a mistake could take on a new signiture pattern.
This is all of course if the job you have done with the dowel is so noticable it bothers you.
Pete
Pete
Re: Little help
Hi Pete,Pete wrote:Hi Jeremy,
Pete
I think it will be barley noticeable now that I have cut the slots etc. so disaster avoided. Thanks for the info. I too am looking forward to number two. It will be so much different going into it with my eyes wide open
Jeremy D
