The b/s are blackwood from Tim Spittle, the top is Engleman spruce, i'm just scraping the recurve at the moment [BY HAND, NO CNC INVOLVED HERE !!!!
Cheers,,, Rod
I found french polishing Engleman a bit of a challenge.....took some time to tame some nibs that kept poking through the shellac. I ended up doing a couple of egg white sizing sessions followed by a light sand back.rocket wrote:Thanks for the thumbs up you lot, Martin, the Engleman is definitely different to Sitka to work with but not in a negative way, if you were to use the word "fury" i'd say that the shavings come off a little bit fury maybe. But it planes and scrapes quite well,
Cheers,,,
Users browsing this forum: No registered users and 137 guests
