I have yet another question to ask. I'm probably getting ahead of myself, but I would like to ask if anyone knows how to do a satin finish instead of gloss. Kind of like on Matons, for example.
Cookie man wrote:
CheersOh and I'm 18 today!! just thought you'd like to know..
All you need is satin lacquer. A gloss lacquer is a clear resin in solvent. Spray it on and the solvent evaporates, leaving the resin. Manufacturers reduce gloss by adding goop called flatting base, the flatting base particles prevent the formation of a smooth surface at the microscopic level. If you open a can of satin finish that hasn't been moved recently, you will see the milky flatting base at the bottom of the clear gloss lacquer. This must be stirred to distribute the flatting base evenly.Cookie man wrote:how to do a satin finish instead of gloss
I'd bet money the /30 stands for 30% gloss. Manufacturers usually offer lacquers in varying gloss levels.Bob Connor wrote:Maton use Mirotone 3220/30 for their satin finish, or at least they used to.
Neither do Irocket wrote:I don't like gloss finishes on guitars![]()
Users browsing this forum: No registered users and 90 guests
