Malaysia Spring
Malaysia Spring
Hi Folks, here are some rosette i did recently for some new guitars that'll be on display ( for sale ) at the coming Osaka Guitar Show 2012. enjoy!
Re: Malaysia Spring
They really take me away somewhere.
Re: Malaysia Spring
Those are beautiful. I look forward to seeing the whole package.
Re: Malaysia Spring
I really like those Jeffrey. What woods do you use? Can you tell us how each leaf is constructed?
Re: Malaysia Spring
Here are some idea how to make the leaves, you can also use other wood which has striking cross grain, the wood i used for the leaves are pine( green ) and rengas ( red ). You can also laminate together other pieces of colour wood to make other pattern you like.
First you cut and glue book match blank with a maple veneer in between and later shape it like a leave and bound it with another layer of maple veneer. Cut into slices of about 2mm thick and use them like other inlay materials. For the rosette, I inlay the leaves and later cut to size of the rosette using a router. I use superglue to seal the pores before finishing. Hope the pictures explained what I'm trying to say. Enjoy!
- rose11a.jpg (278.3 KiB) Viewed 13810 times
- rose33.jpg (428.05 KiB) Viewed 13810 times
- rose11.jpg (395.92 KiB) Viewed 13810 times
Re: Malaysia Spring
Beautiful work Jeff (as always) and very kind of you to share this great tip with us. Must ask if you would you mind posting a version of your method in our tutorial section? It would be a simple matter of copying and then pasting what you have shown here into a new topic.
viewforum.php?f=5
Perhaps you could rename it " Making wooden leafs for inlay". That way anyone searching the word "inlay" may be inspired by your simple yet affective and very attractive method..I know I have been
viewforum.php?f=5
Re: Malaysia Spring
That is a brilliant technique Jeff. Thanks for sharing it!
Re: Malaysia Spring
Wow Jeff ,
wood like that must help out a sale , thats super stunning !!
- Taffy Evans
Re: Malaysia Spring
It's those little tips and tricks that really make this place work Jeffrey. Thanks for that, and some more outstanding work from you as we've come to expect.
- Shane Briggs
- Gidgee
- EricDownunder
Users browsing this forum: Google and 110 guests
