Titebond liquid hide glue for the bridge?
Kim de Rijke
Post by Kim de Rijke » Sat Jul 21, 2012 11:07 pm
What's the opinion on using Titebond LHG to glue down the bridge? I searched the forum for a similar thread but couldn't find it (although I understand there seem to have been some concerns about the general quality of the glue in the past). I bought a small bottle from Carba-tec recently but thought I'd consult first. I'm French polishing at the moment (with the bridge area taped) if that is relevant.
Thanks,
Re: Titebond liquid hide glue for the bridge?
Post by charangohabsburg » Sun Jul 22, 2012 12:07 am
Kim de Rijke wrote:(although I understand there seem to have been some concerns about the general quality of the glue in the past).
Exactly. And this is why I never ever would use it for any structurally challenged joint. I recommend you to stick with Titebond original (the one with the red label) or hot hide glue. If I had bought Franklin's liquid hide glue I would use it for less important joints and when used up not replace it. It's just not worth the risk.
lauburu
Post by lauburu » Sun Jul 22, 2012 6:09 am
Bought some Carbatec LHG once and used it on a structural joint. Epic fail. Don't know whether it was the poor quality of the glue or just simply its inability to set hard enough. Never again
J.F. Custom
Post by J.F. Custom » Sun Jul 22, 2012 9:12 am
Avoid.
I believe I was told once it also contains formaldehyde (?) to keep it 'liquid'. Whatever - it simply does not set as hard or have the structural integrity of true HHG. They are very different beasts. Don't use it - particularly for such a stressed joint as the bridge.
Paul B
Post by Paul B » Sun Jul 22, 2012 8:36 pm
If it doesn't set up as hard, then you're in all likelihood going to get creep. Gluing a bridge is the exact area where you want to avoid creep.
Post by kiwigeo » Sun Jul 22, 2012 9:31 pm
Kim de Rijke
Post by Kim de Rijke » Sun Jul 22, 2012 9:53 pm
I somehow knew it :cry: but happy to have followed my gut feeling and receive the message loud and clear. I'm sure you guys saved me a lot of grief; great forum! :cl
Kim.
Users browsing this forum: No registered users and 132 guests
