Query on mic preamp settings
Post by kiwigeo » Thu Aug 02, 2012 9:23 pm
Ive got an SMProaudio XMP1 mic preamp that has a switch for 12volt phantom power. Theres no annotation on the unit to show on or off position and nothing in the manual.
Anyone know which way is on/off for the phantom power switch?
MBP
Re: Query on mic preamp settings
Post by MBP » Thu Aug 02, 2012 9:52 pm
I dont know which is on or off but if you have a multimeter or volt meter it is easy to tell.
On you multi meter set it to volts dc and touch pin 2 and 3 and flick the switch with it plugged in and turned on.
graham mcdonald
Post by graham mcdonald » Fri Aug 03, 2012 8:18 am
If you are using it with a condenser mic which needs phantom power, the on position will be when the mic works. If your mic doesn't need phantom power it doesn't matter which position the switch is.
Graham
Graham McDonald
Post by kiwigeo » Fri Aug 03, 2012 8:40 am
Thanks chaps.....especially The Phantom
graham mcdonald
Post by graham mcdonald » Fri Aug 03, 2012 9:56 pm
Couldn't resist the temptation to be a bit of a smartarse :D
Graham McDonald
