7 String Falcate Flamenco
Post by jeffhigh » Wed Aug 22, 2012 11:28 am
EIR/ Englemann
Now ready for neck fitting
Re: 7 String Falcate Flamenco
Post by kiwigeo » Wed Aug 22, 2012 12:54 pm
Nice looking gat Jeff. Have you done any sound spectrum analysis of the free plate top/back and closed up box?
Post by jeffhigh » Wed Aug 22, 2012 1:20 pm
Not Yet,
I dont see a lot of worth in free plate, I'll do the box when it's finish sanded, but I found on the last two that the frequency changed when I added the neck and in a major way when I added the bridge.
I don't use a bridgeplate on nylons so it is still pretty loose until the bridge goes on.
Post by Trevor Gore » Wed Aug 22, 2012 6:07 pm
Love that height-adjustable work bench!
Post by jeffhigh » Wed Aug 22, 2012 7:10 pm
I reckon it's saved MY back in the 15 years I've had it
Post by charangohabsburg » Fri Aug 24, 2012 1:07 am
jeffhigh wrote: [...], but I found on the last two that the frequency changed when I added the neck [...]
That sounds interesting to me. Which frequency did change? And how (+ how much?) did it change? The neck as "side mass"?
Post by jeffhigh » Fri Aug 24, 2012 7:11 am
Yeah. neck as side mass, dropped the top around 2Hz. I know Trevor has said that was not his experience, but with my body shape etc, it did it in a measurable and repeatable manner.
Post by charangohabsburg » Fri Aug 24, 2012 9:06 am
jeffhigh wrote:Yeah. neck as side mass, dropped the top around 2Hz. I know Trevor has said that was not his experience, but with my body shape etc, it did it in a measurable and repeatable manner.
I imagine that if one can measure a difference of the fundamental top frequency or not might depend on the stiffness difference of the body structure with and without attached neck. If there is a big enough stiffness difference (stiffer with neck attached) this might eliminate the neck's "side mass effect" on the top fundamental frequency.
That's just my conjecture, of course.
Post by jeffhigh » Fri Aug 24, 2012 10:10 am
That may very well be
My design uses a cantilevered fretboard extension so it adds no stiffness to the top only mass
Post by jeffhigh » Wed Sep 05, 2012 11:23 am
Walnut bridge with 2 layers of CF
Currently at 12.5 grams(without saddle) and with a bit more sanding remaining
21 hole tieblock
Post by Dominic » Wed Sep 05, 2012 11:26 am
Hey Jeff, is that american walnut or Qld? Pretty light so far. And longer saddle area. I like 21 holes, so much neater not having the string wrap over the tie block.
Look forward to the finished thing.
Post by jeffhigh » Wed Sep 05, 2012 11:31 am
American black walnut, cant stand the smell of the QLD plus it is quite heavy.
This stuff doesn't smell great but not totally disgusting.
Yes, longer saddle section for the 7 string but I only added 5mm to the total length
French polishing the body now
Post by kiwigeo » Thu Sep 06, 2012 8:30 pm
All looking good there Jeff. Looking forward to seeing the finished instrument.
Post by Dominic » Fri Sep 07, 2012 1:42 pm
Hey Jeff, I saw a vid on youtube of your on-the-fly adjustable guitar neck. (That is your guitar isn't it?) Have you put up any pics of how it works? Does your heel move in a recess in the headblock or do you just let there be a gap? And what is your pivot point?
I have been doing raised fingerboards with one bolt on my classicals so I am only a few details away from making it adjustable. But I have not yet resolved in my head a design that I am happy to put on both a non-cutaway and a cutaway. I might have to do two different designs.
Post by jeffhigh » Fri Sep 07, 2012 2:39 pm
Pretty simple Dom
My neck is cut off 5mm longer than the joining fret at the appropriate angle
The neckblock has a 6mm insert about midway down on the inside face.
After the body is closed and the fretboard fitted to the neck ,I shim the neck to the right height, I insert a sharpened bolt from the inside of the body and use that to scribe the end of the neck.
I drill a 6mm hole through the heel at an appropriate angle (on a platform on my lathe bed)
I mount the neck to the body with a bolt/strapbutton and scribe for the pocket which I cut a little undersize and creep up on a good fit
The pocket is 6mm deep and the pivot is just a strip of 3x1mm CF glued to the top edge.
Have not done a cutaway, I think Craig did.
Post by Dominic » Fri Sep 07, 2012 8:27 pm
Thanks Jeff, one more thing, how much room do you need at the bottom of the heel to go from a low action to a high action. It wouldn't be much. 1 to 5 ratio or so?
For a cutaway I want a nice smooth joint where the hand goes. So I could deal with a small gap for a high action and no gap for a low action but I don't want any overlap like I've seen on some Doolins. I've been tossing up ideas in my head for months about how to design it so I can execute it well. I'm at the stage where i need to do some mock ups so I was interested in different approaches .
And your vid was really cool.
Post by jeffhigh » Sat Sep 08, 2012 7:26 am
Dominic wrote:Thanks Jeff, one more thing, how much room do you need at the bottom of the heel to go from a low action to a high action. It wouldn't be much. 1 to 5 ratio or so?
You are only talking a mm or so from high to low. If I get the neck angle right just that 1mm elevation at the pivot is enough to give plenty of range.
I have not done a cutaway yet, and have not come to any conclusions about how I would do it.
Like you I would prefer to have a smooth transition from neck to cutaway, so I am interested to see what you come up with.
Post by Dominic » Sat Sep 08, 2012 8:53 am
Thanks Jeff, once I have my ideas resolved I'll mock it up and post the results. My problem is that once I get motivated I want to do all the projects I have been thinking about and I have already committed myself to finish my bass, make a couple of CS356's and do these clones with all the jigs making. Surprisingly everything is moving forward but this neck joint is a priority so I can imagine dropping everything else once the inspiration strikes.
Post by jeffhigh » Wed Sep 12, 2012 8:32 am
Vacuum clamping the bridge with HHG
Post by jeffhigh » Wed Sep 12, 2012 8:33 am
40 minutes later, all cleaned up
Post by jeffhigh » Wed Sep 12, 2012 4:09 pm
The T(1,1)2 went up around 10 HZ to 189 with the bridge glued on
I'm expecting that with the added mass of the saddle, golpeador, strings, neck (side mass) and the effect of bringing down the back frequency, I will approach 180
Post by kiwigeo » Wed Sep 12, 2012 4:49 pm
Any chance of a look at the full spectrum Jeff?
Post by jeffhigh » Wed Sep 12, 2012 6:00 pm
Ok lets try this
At the moment, its 87, 189, 265
Post by jeffhigh » Wed Sep 19, 2012 3:27 pm
Strung up for setup and tuning of resonances.
Then probably bind the soundhole and a bit of finish touchup.
Post by kiwigeo » Wed Sep 19, 2012 3:39 pm
Looking good there Jeff...
Users browsing this forum: No registered users and 145 guests
