45deg chamfer router cutter
Onlinekiwigeo
Trev,
When you rout out your classical bridges you use a 45 deg chamfer cutter for the ramp aft of the saddle slot. The only cutters I can find have a guide bearing on the bottom. Could you kindly provide name of supplier of the cutters youre using.
Cheers and thanks Martin
Re: 45deg chamfer router cutter
Mine's a no-name cutter I got in a sale at Carbatec. It was from a boxed set that had a few bits missing that they were selling off cheap. It's one of those with the sickly green colour.
Try looking under Vee Groove Bits. Carb-i-tool do quite a wide variety from 22.5 degree through 150 degree, including, of course, a 90 degree, which looks pretty much like mine.
http://www.carbitool.com.au/
http://www.carbitool.com.au/router_catalogue.html (third row)
Onlinekiwigeo
In your book youre using a 45 degree cutter arent you? Cant see any 45 degree cutters in any of the links.trevtheshed wrote:
The V-groove bits are specified by their included angle, so 90 degree included angle cuts a 45 degree chamfer.
Onlinekiwigeo
Oh right...of coursetrevtheshed wrote:The V-groove bits are specified by their included angle, so 90 degree included angle cuts a 45 degree chamfer.
Onlinekiwigeo
Ok these are the babies....item T112 on the link below. Ive used these guys for sourcing cutters many times in the past and have found their service good.
http://www.apworkshop.com.au/html_route ... b-vgb.html
- J.F. Custom
Martin,
They are readily available.
http://www.carbatec.com.au/815-v-grooving-bits_c18020
CMT are good quality bits.
Worth a look is McJing Tools Online. I've bought some gear fom them (mainly because I can't afford expensive tools)
Part No: JL7729
Stuff I've bought seems pretty good and they're quick to deliver.
Part No: JL7729
Onlinekiwigeo
Thanks Nick. The CMT cutters dont come in the size I need....3mm diam across the cutter.J.F. Custom wrote:Martin,
Not sure if you're using this cutter for bridges, Martin, but the V-groove cutter I use for bridges is half inch (12.7mm) cutter diameter (1/4" shaft). The veining bit I use to reveal the string holes is 3.2mm.
Onlinekiwigeo
Yes again youre right...got my cutters mixed up.trevtheshed wrote:Not sure if you're using this cutter for bridges, Martin, but the V-groove cutter I use for bridges is half inch (12.7mm) cutter diameter (1/4" shaft). The veining bit I use to reveal the string holes is 3.2mm.
Cutters just arrived.......ordered yesterday got here the next day. Cant ask for better service than that. APworkshop come through with the goods again.
The bridge will have to wait...busy knocking up an external mold today. The next classical will be a bolt on neck affair.
