I would concur, not to use the silicon additive, it will not only contaminate every spray job you do, it will piss every person off there after that may have to do a repair on the guitar. (Yes that would include me)
Do you have a water trap on your spray line, spraying is very easy when you know the basics and adhere to the basics. Not having a water / oil seperator is a bad start to any paint job.
FISHEYES
Re: FISHEYES
Allen sidelines for a company called "beery", a direct competitor of SMOOTHIE hence the bad naming......
Re: FISHEYES
I haven't used a HVLP turbine unit, but just based on my reading, I didn't think there was any place to insert such a trap in the same way as on a conventional compressor and hose system. But I could be wrong about that.....simso wrote:I would concur, not to use the silicon additive, it will not only contaminate every spray job you do, it will piss every person off there after that may have to do a repair on the guitar. (Yes that would include me)
Re: FISHEYES
Had not considered that, you could be right
Re: FISHEYES
None of the turbine systems I've seen would use a oil and water trap.
I was referring to a conventional compressor system that should have both installed.
