Looks like a guitar
Looks like a guitar
Some pictures of an all mahogany OM that I finished recently.
Plain and unadorned, it looks like a guitar and even sounds like one.
Top back and sides Macassar mahogany bought on eBay.
Neck Qld maple
Finger board EI rosewood
Tuners Golden Age from Stewmac
[/attachment]
Neck Qld maple
[/attachment]
Bruce Mc.
Re: Looks like a guitar
I like that a lot - good job! The 'plain, unadorned' look has always appealed to me.
What was your finish type and procedure?
Dave Bagwill
Get your facts first, then distort them as you please. - Mark Twain
Beautifully simple and elegant Bruce, love it.
Although I'm a bit sus on the plant in the background of the headstock shot, seeing as it's in Canberra I thought maybe that's what makes the politicians carry on like children during question time
Matt
Very cool looking guitar you've made there Bruce. Loads of class & style..
Ditto, ditto and ditto.
Nice. And, yes, please what did you finish with. I want that satin look on my current one....I've got tru-oil....
Hi Dave
The finish is Danish oil, several applications worked in with 400 and 600 wet and dry.
Initially I sealed the body/neck with dewaxed blonde shellac then started the oiling using
400 wet and dry to spread the oil. I applied the oil generously and evenly then wiped off
any excess with a clean soft cloth after about 30 mins. Then I left it for a couple of days
until the surface was dry before applying the next coat. I repeated this procedure changing
to 600 wet and dry.
to 600 wet and dry.
Bruce Mc.
I recently had a rather enjoyable half hour playing this fine instrument in the hallowed halls of Parliament House.
While noodling away on a bit of The Oils 'No Reaction', I started to wonder if Pete would poke his dome in through the doorway & give us a dance.
You've done well with this one Bruce!
Thanks for the kind comments.
Dear Matthew
The vegetation you refer to is a seven lobed dissected leaf variety of Acer palmatum, very common in Canberra.
I have no idea as to what you are alluding to. (TICFIB)
This guitar was partially completed when I attended Trevor's course in June, so I was not able
to apply everything I learnt at the course to this one. I will only say that the resonant frequencies
for T (1,1)1 and T(1,1)2 are well above the suggested ranges and there is no obvious T(1,1)3.
I have fiddled with the bracing and sound hole diameter to move the resonant frequencies away from
note frequencies. I think it worked.
Dear Matthew
Bruce Mc.
Thanks Bruce, I'm glad it has worked out well for you, it certainly looks the goods.
Thanks also for the info on Acer palmatum ( Now that I think about it that might be the politicians problem, they're smoking the wrong plant
Matt
- ozziebluesman
Very nice Bruce. I like the all mahogany look. Your headstock looks grand and the workmanship is first class.
Thanks for sharing the pictures.
Nice one Bruce. Very Martinesque.
I bet it sounds killer with 13s and a slide.
