Okay not a major disaster but Im kicking myself for not being more careful.
Ive just drilled out bridge pin holes on a steel string and one or two of the hole are a tad too big....ie the pins bottom out in the hole.
Any ideas? Filling the holes is one option. Oversized pins is the other option I guess. Might be a good enough excuse to make up my own pins.
Cheers Martin
Cheers Martin
- graham mcdonald
Couple of possibilities
Lining the holes with a couple of coats of super glue and them re-reaming the holes. (a little bridge pin reamer is a good thing to have)
or
Making some thin shavings of whatever wood the bridge is made of and gluing them in the holes and then re-reaming, effectively bushing the holes.
or
Making another bridge
I think we have all overdrilled bridge pin holes at one time or another.
graham
or
or
graham
Graham McDonald
- Kim Strode
Hi Martin,
I made a similar mistake recently, although it was not on a guitar, so not as serious.
I rectified the problem by glueing taped pins (which I turned on a lathe) into the oversized holes with superglue. By making the pins tapered I was able to ensure a tight fit and the excess was removed with a small scraper plane.
The same idea might not work in your case, as there won't be much material left around the peg. As you said, the answer might be to turn your own oversized pegs.
Don't be too hard on yourself, we all make these sort of boo-boos!
Regards,
Regards,
Kim Strode
Daylesford, Australia
- Dennis Leahy
Hey Dennis,Dennis Leahy wrote:Kim, Where'd you get that picture? That is not your work. No way, no how.
I got the image from the OLF, it was a joke posted by James Burkett. James was replacing the top on this guitar and did not want to save the generic bridge. His sense of humour insisted that he remove the top as shown so he could take an image and post it in a "Slotting the bridge for slotless pins" thread. If it was my work, no way could I post such an image
Onto more serious stuff. I dabbed a bit of superglue into the oversized holes as suggested by Graham Mac and I do believe it might do the trick. The pins now go in alot tighter. A little fine tuning with the reamer and they should be fine.
Wonderful stuff that superglue.
Now onto the next little problem..finding the bldi screws that came with the Schaller machine heads.
- Dennis Leahy
Craig, it would always have bothered you, so good for you for whacking it off! (I don't believe I've ever said that to anyone! )
Now you have me wondering about how those current holes will line-up (or not) with the new holes you'll drill. Will you plug the holes in the top, or not worry about that?
Another damn Yank!
Hi Dennis, was thinking about the holes in the top yesterday and have decided that because the new bridge will be exactly the same shape and only one hole is slightly off line Ill block up the hole in the top for that hole only.Dennis Leahy wrote:Craig, it would always have bothered you, so good for you for whacking it off! (I don't believe I've ever said that to anyone! )![]()
Cheers Martin (the other kiwi on here)
With you there Craig. Onya Martin your tenacity is inspiring....but then that is the first quality of a true craftsman.Craig L wrote: Martin Geez , you sure have had your share of 'learning experiences 'latley. I really feel for you . Bravo on taking the higher ground . I can say quite confidently, Martin does it "Right " On ya mate .
Cheers ,Craig
Okay Ive finally got a new bridge made up and managed to get the pin holes perfect. I also managed to make a perfect slash on the end of my finger open with a freshly sharpened paring chisel (dont ask me for details) so no more guitar building for a couple of days. Nose picking will be off the agenda also.
- Dennis Leahy
Users browsing this forum: No registered users and 128 guests
