Simple Easy Tool
- Tod Gilding
Simple Easy Tool
I was recently setting up my latest build,getting my nut slot to an exact depth when John the woodrat introduced me to a very simple but effective tool, The Stew Mac String lifter,this tool is fantastic for something so cheap and simple, so anyone like me that does not know about these things I recommend having a look.
I have also convinced Rob from my tool store to stock these for Australian buyers,along with his other stew Mac Products ( I have no connection to My Tool Store)
http://www.mytoolstore.com.au/products/ ... ifter.html
Re: Simple Easy Tool
I bought one of these a while ago. Honestly, I found it just took longer than doing it the 'usual' way.
- Tod Gilding
I'm Amazed Perry
I was slacking off strings cutting the slot a little and bringing the strings back to tune re checking and if it wasn't right doing it all again and again with this thing it's 1 second to drop the string out of the slot file same tool puts the string back into the slot 2 second job. but what ever you find works for you I suppose
I got a few of these from SM a couple years ago. Use them all the time. Neat little tool.
Reason: Corrected posters name
You're too modest Dom!Dominic wrote:I got a few of these from SM a couple years ago. Use them all the time. Neat little tool.
Dim
I bought one earlier this year when I bought some fret wire to get a Uke finished. Unfortunately it my haste to get at the fret wire that I forgot all about the string lifter and must have thrown it out with the packaging. (DOH must have had to many of these
Matt
I would agree, when I bought one, I thought this is great, loosen the string off lift it with the lifter cut the nut lift the string back in and bring back to pitch, went and bought another 4, I was that impressed, it lasted about a week or two.Ormsby Guitars wrote:I bought one of these a while ago. Honestly, I found it just took longer than doing it the 'usual' way.
Now, they sit in the draws. Takes less time to simply lift it with the old fingers than go looking for a special tool to do the job.
simso wrote:I would agree, when I bought one, I thought this is great, loosen the string off lift it with the lifter cut the nut lift the string back in and bring back to pitch, went and bought another 4, I was that impressed, it lasted about a week or two.Ormsby Guitars wrote:I bought one of these a while ago. Honestly, I found it just took longer than doing it the 'usual' way.
It's one of those tools I show people:
"look at all the specialist tools we need..."
"ooo.... ahhhh..."
...then dump it back in the 'special' draw with all the other stuff I dont use
OK ,
Two votes from the west Against, Fair enough they do it 20 times a day.
Does it really matter if we Back shed novices like them , they are only a couple of bucks.
Not Like Tod is recommending a $1000 peice of equipment that's shit !
Just Sayin !!!!!
Just Sayin !!!!!
Paul .
Think wed better correct that typo....Dominic wrote:I got a few of these from SM a couple years ago. Use them all the time. Neat little tool.
Dim
68matts wrote:I bought one earlier this year when I bought some fret wire to get a Uke finished. Unfortunately it my haste to get at the fret wire that I forgot all about the string lifter and must have thrown it out with the packaging. (DOH must have had to many of these![]()
How do you go unwrapping tonewood???
I've found they can dint/marr softer fretboards if you use it as prescribed so I don't use mine any longer either. I mainly work on electrics so I guess different strokes etc but just a heads up.
I haven't seen one of these before, I take it you still have to de-tension the string to an extent,in order to get this thing to lift the string out the way? It takes me all of a few seconds to de-tension the string some, half a second to lift the loosened string with my fingers & drop it into a neighbouring slot & re-tension the string. I'm afraid I'd be with Perry & Steve on this one as a "I can't see the point" tool.
I usually try and do that when I'm sober
Matt
- Tod Gilding
Nick, No you don't have to take any tension off, that's why I like this, easy out of the slot and easy back in all with the strings at standard tune.
I can see the point that it could dent a soft fingerboard, but how many builders use soft fingerboards ?
I have used it with a rosewood board with no marking of the board at all.
I didn't expect to open a can of worms here
No can of worms, just an alternative view.
You gotta remember, a lot of people who might do something once a month (or once a year!), recommend things on these forums.
There are others that do it day in, day out.
If it works for you, knock yourself out.
Ive used these sporadically during my guitar building classes, because the guys just LOVE all the little tools. Sure, I find them a waste of time, but the novelty of a weird little tool, and the excitement the students have in using one after discovering it, is worth it. It's all part of the course... show them a couple different ways of doing things, and they'll find their groove.
However, as someone else said, they can mark a fretboard (rosewood and maple) when used with regular or larger acoustic sized strings and an average (or steeper) headstock angle.
- Tod Gilding
Agreed Perry , I enjoy hearing all the alternative views, and someone doing it day in day out will obviously have a differing take on the processes. Thats why I find the ANZLF a valuable resource.
would you mind detailing your Alternative process without using the lifter ? Any tips, tricks ?
grab the string near the bridge, slide your fingers up towards the nut, underneath, and pop it out of the slot. No need to detune, retune, etc etc.Tod Gilding wrote:Agreed Perry , I enjoy hearing all the alternative views, and someone doing it day in day out will obviously have a differing take on the processes. Thats why I find the ANZLF a valuable resource.
- Tod Gilding
Ormsby Guitars wrote:grab the string near the bridge, slide your fingers up towards the nut, underneath, and pop it out of the slot. No need to detune, retune, etc etc.Tod Gilding wrote:Agreed Perry , I enjoy hearing all the alternative views, and someone doing it day in day out will obviously have a differing take on the processes. Thats why I find the ANZLF a valuable resource.
For some reason I was expecting a new trick, but yeah that works, Thanks mate
No worms here, I've had me tablet & flea treatment just recentlyTod Gilding wrote:Nick, No you don't have to take any tension off, that's why I like this, easy out of the slot and easy back in all with the strings at standard tune.
I suppose it's good that you don't have to retune but do you have to hold the wee doohicky while you work on the slot? Personally (and that's all it is) I like to hold my nut file with both hands for better control (one at the tip and the other at the handle stops any chance of 'rolling' the file in the slot laterally or longitudinally), it's just my engineering training coming through
- Tod Gilding
Nick, I like to hold my nuts with both hands as well
Just when you're filing them, or all the time?
Yeah well one day Mr Thrill Seeker ur gonna break a fingernail do'in that and then you'll see why Dan the 'Stewmac Superman' spent countless days at the bench just scrath'in his Optivisor to come up with the mighty string jack...Ormsby Guitars wrote: grab the string near the bridge, slide your fingers up towards the nut, underneath, and pop it out of the slot.
I have one of those string jack draws to Perry, it has all kinds of guitar 'stuff' in it including a string jack I don't use but there is other guitar stuff I simply would not be without such as the trusty Dunlop Turbotune string winder (remove crank handle and fit hex drive shaft of head to any cordless driver
If some of you blokes spent less time thrashing yourselves senseless you'd have enough strength left in your fingers to wind your tuners without having to use a fancy gizmo.
