So back to the original question
Anyone know a Sydney supplier? The ones I've found charge an arm and a leg. I have a tall go-bar deck, so need ~1.2m lengths.Kim wrote:Not sure of the diameter of the stewmac rods or perhaps they're flattish in profile?? Anyhow I made my own gobars from 1/4" fibreglass rod. A local plastics distributor sells it in 3m length...
Unless using a riser, @ 1.2m between surfaces you may find you will need to go up in size to 8mm GB's Trev.trevtheshed wrote:Anyone know a Sydney supplier? The ones I've found charge an arm and a leg. I have a tall go-bar deck, so need ~1.2m lengths.Kim wrote:Not sure of the diameter of the stewmac rods or perhaps they're flattish in profile?? Anyhow I made my own gobars from 1/4" fibreglass rod. A local plastics distributor sells it in 3m length...
Phil Mailloux wrote:Those of you who happen to have or have used stewmac go bars, did you do anything to them or are you using them 'out of the box', those bars are putting some mean denting onto my braces, I'd love to use the O'Brien method of gluing the top and back to the sides in the go bar deck but the way these bars are, they'd do way too much denting in the material, I see he's using the lmii go bars that have plastic caps at the end, so such thing on the stewmac ones.
So back to the original questiondid you sand the end of your go bars, wrap them with something, etc..?
That's a good tip especially for the flat profile of SM's gobars.steve_I wrote:Dear Phil,
I "plasti-dipped" the ends of my Stewmac go bars - but still use a some sort of caul between the bars and wood that I am clamping.
4 dips of plasti-dip puts a nice "rubber" end on one end of the bar.
Steve.
I bought the Stew-Mac go-bar sticks long, long, long ago, when they were around $2.50 each, around half the price they are now (I'm glad I bought them then!). (Before that, I was using wood dowels, which I would sand to kind of a rectangular shape at the ends. But sometimes the wood dowels would crack and I'd have exploding, flying go-bars!!! That's why I went to fiberglass bars.) I like the rectangular fiberglass bars because they're nice and sturdy and dependable, and they don't spin around, which the round fiberglass ones might do. I don't do anything to the ends of the bars --- if I'm clamping something soft, I'll usually put something as a caul over it (like popsicle sticks over braces), unless it's a section of the brace that will be carved away anyway. Then I don't bother with a caul. I love my go-bars. When I bought them, I bought 36 of them, and that has proven to be a good number to have. (But today, I don't know that I'd buy them at the price they are at now.)Phil Mailloux wrote:Those of you who happen to have or have used stewmac go bars, did you do anything to them or are you using them 'out of the box', those bars are putting some mean denting onto my braces, I'd love to use the O'Brien method of gluing the top and back to the sides in the go bar deck but the way these bars are, they'd do way too much denting in the material, I see he's using the lmii go bars that have plastic caps at the end, so such thing on the stewmac ones.
Thanks for the sourcing options everyone. Goodwinds have a good variety at good prices. If any of you want heavier duty rods, one option is 10mm fibreglass electric fencing rods, which are available from farm suppliers at a reasonable price.trevtheshed wrote: Anyone know a Sydney supplier? The ones I've found charge an arm and a leg. I have a tall go-bar deck, so need ~1.2m lengths.
Phil Mailloux wrote:That plasti stuff looks great, where can you buy it?
Users browsing this forum: Google and 104 guests
