String breakage
String breakage
Post by jeffhigh » Wed May 15, 2013 5:37 pm
Hi Guys, looking for some advice.
I've got a player who is breaking a lot of strings (D and G) on his Cole Clark acoustic while playing gigs with a duo.
They are always breaking at the saddle.
I have smoothed the saddle, the break angle is not excessive.
12-53 d'Addarios both coated and plain
He thinks there is a problem with the guitar, I am inclined to think he is just playing a lot harder in the duo situation.
Any suggestions, is going to mediums worth exploring?
Tod Gilding
Re: String breakage
Post by Tod Gilding » Wed May 15, 2013 6:26 pm
Just a thought Jeff ,could it be possible that the string has cut into the soundboard and is being cut by the metal on the under saddle Transducer, er , I mean under saddle house brick.
nnickusa
Re: String breakage
Post by nnickusa » Wed May 15, 2013 7:02 pm
Um, wow. that's some serious gear. Is that waht they all look like inside?
Yikes
Re: String breakage
Post by jeffhigh » Wed May 15, 2013 7:03 pm
No, just breaking on top of the saddle.
Re: String breakage
Post by Kim » Wed May 15, 2013 8:26 pm
Jeff, if you've smoothed the saddle and he's still breaking the same strings then its probably him being heavy handed as you suggest. Maybe he's just not hearing himself in the duo situation and needs a better monitor. To prove that point you could try flossing the saddle in situ right in front of the guy so he can see for himself that the strings have an evenly supported run over the bridge.
Steve.Toscano
Re: String breakage
Post by Steve.Toscano » Wed May 15, 2013 10:50 pm
jeffhigh wrote: d'Addarios
Not the best quality strings. Maybe a combination of crappy strings and his hard playing style.
Re: String breakage
Post by Nick » Thu May 16, 2013 6:30 am
What a terrible looking pickup system! :oops: :oops:
It's certainly a head scratcher after you've smoothed the saddle, especially as it's the thicker D & G (I could understand the B or high E).
Would the guy entertain fitting a wider saddle? What I'm thinking is that the string is sitting on the contact point of the 1/8th saddle then immediately leaving the saddle so there is only that small point of contact, under 'normal' circumstances this would be acceptable. If he is a heavy hitter then the top of the saddle is effectively acting as a stress riser, almost a knife edge. A wider saddle will allow you to radius behind the break point so the string 'rolls' off the saddle increasing the contact area and spreading the load over 2-3mm of the string (ala Ervin Somogyi) and doesn't create that single stress point, it's how I've been approaching my saddles now.
Just a thought to consider.
hepikohetaniwha
Re: String breakage
Post by hepikohetaniwha » Thu May 16, 2013 7:34 am
Since it's the strings in the middle that are breaking, I wonder if the radius on the saddle is too small for his right hand style. Perhaps flattening the radius would help to spread the load, so to speak, over all six strings. ..or will that mean he starts breaking all six? :)
Tod Gilding
Re: String breakage
Post by Tod Gilding » Thu May 16, 2013 4:44 pm
nnickusa wrote:Um, wow. that's some serious gear. Is that waht they all look like inside?
Yikes
Here's The Maton Nick :roll:
nnickusa
Re: String breakage
Post by nnickusa » Thu May 16, 2013 5:50 pm
Just as ugly, the Maton.....Can't imagine it'll add to the stability of the top in the long term....
Re: String breakage
Post by simso » Thu May 16, 2013 8:17 pm
Tod Gilding wrote:Here's The Maton Nick :roll:
Looks like a maton mini
Re: String breakage
Post by simso » Thu May 16, 2013 8:20 pm
nnickusa wrote:Just as ugly, the Maton.....Can't imagine it'll add to the stability of the top in the long term....
There actually pretty stable, especially when you consider your bonding a 5mm lump of rosewood to the top surface, the electronics on the other hand can be very fiddly, individual little magnets with individual caps screwed up under a plate
Users browsing this forum: No registered users and 224 guests
