Shielding on electric guitars.
Re: Shielding on electric guitars.
Post by kiwigeo » Wed May 15, 2013 8:58 pm
I've heard of aluminium foil being used for shielding and also copper paint. Haven't heard of brass (foil?) being used.
I imagine aluminium foil would be the cheapest option but probably doesn't look too professional. Stewmac and others market a conductive copper based paint specifically for shielding use.
nnickusa
Post by nnickusa » Wed May 15, 2013 9:00 pm
Both are highly conductive, but copper tape is cheap on eBay. Like $5-10 a guitar, and easier to work--softer and less brittle that is.
Post by kiwigeo » Wed May 15, 2013 9:20 pm
needsmorecowbel
Post by needsmorecowbel » Wed May 15, 2013 9:28 pm
I used the Stew Mac Shielding Paint on Monday to shield a crappy Chinese strat I picked up from a pawn shop. It's good stuff but then so is the Copper tape you can get from Stew Mac...Much of a muchness really. Have never used aluminium tape but between those three options you can't really go wrong.
Stu
Steve.Toscano
Post by Steve.Toscano » Wed May 15, 2013 9:41 pm
I use copper tape. This stuff - http://luthierssupplies.com.au/product_ ... cts_id=725
Have used it on 60+ electrics now, and am nearly finished my second roll.
P Bill
Post by P Bill » Thu May 16, 2013 3:58 am
The adhesive on copper tape is conductive, the adhesive on aluminium is not. I use a small strip of copper to bridge any joins.
Matt Bach
Post by Matt Bach » Thu May 16, 2013 6:29 pm
The tape shields really well but I've found that the adhesive can fail after a few heat cycles (at least with my "left me guitar in me car again" customers) so I go with the paint option. It's also easier to get in the nooks and crannies and you can even dribble it down holes, easy clean up, next to no waste.
needsmorecowbel
Post by needsmorecowbel » Thu May 16, 2013 6:42 pm
Matt Bach wrote:left me guitar in me car again"
It seems like every guitar tech has a "left me guitar in me car again" story. At what point do you tell a customer that is a repeat offender to politely piss off? Is it the three strikes rule?
Stu
demonx
Post by demonx » Thu May 30, 2013 9:28 am
I have copper shielding tape but don't use it
What I have found makes my guitar silent is a copper plate, cut to fill the elec cavity. All pots and switches are mounted hard against it (pre drilled holes) and this earths them out, then simply wire the bridge earth wire to it, the output jack earth and the pickup earths.
Essentially it becomes the one earth for everything and has eliminated the hum issue I once had that even the shielding tape could not prevent
I can post pics if you need to see
P Bill
Post by P Bill » Fri May 31, 2013 8:01 am
Steve , I'd like to have a look thanks.
demonx
Post by demonx » Fri May 31, 2013 9:54 am
If you pause this clip at the 1:15 mark it'll show what I was trying to explain:
https://www.youtube.com/watch?v=MDuSebNSiD4
Cheers, Allan.
GourmetSaint
Post by GourmetSaint » Thu Jun 06, 2013 1:12 pm
I'm using copper conductive paint from Caswell Australia. It's used as a precursor to electroplating non-conductive materials such as acrylic, wood etc. Much more conductive than the carbon/graphite based paints (like from Stewmac).
Post by simso » Sun Jun 09, 2013 7:29 pm
Shielding is a very interesting topic.
Its extremely interesting to hear from those that say its made a difference for them.
Ive built a guitar or two :wink: repaired one or two as well :wink: :wink: ,but not once have I ever shielded one or had a need to shield one.
P Bill
Post by P Bill » Mon Jun 10, 2013 12:11 am
Steve, some do, some don't. There are many discussions about this out there. No shielding on my archtops , other than the wire. My eubs, piezos and onboard pre, benefit from shielding.
