Schaller M6 mini's - hole spacing for a 12 string
Okay Im pondering over set out of M6 mini machine heads on my 12 string. I plan to set the hole centre 13mm back from edge of the headstock. What I need advice on is spacing between adjacent madhine heads. Initial plan is to go for 25mm. What do others in here use?
TIA Martin
TIA Martin
Nowhere near stringing up the thing Dom,
Body is closed up and bound. Headstock getting bound at present and then Ill rough out the neck and cut the dovetail.
The plans.....I draw them up myself using ideas from lots of places. The body is a standard dreadie (original shape from an instrument I borrowed years ago and traced). Headstock is same as on the 6 string Im building at the moment...think the design came from a picture in a Big Red Book.
Cheers Martin
Cheers Martin
G'day Martin,
I too used 25 mm. between tuners , which seems ample.
I installed Gotoh mini's. They seemed a tad on the heavy side , so swapped out the knobs for their ebony replacement knobs. B.T.W. I think from memory , the Ebony knobs cost bloody near more than the tuners !
It reduced the weight considerably !
Anyone want some Gotoh gold mini knobs ?
Here's my GROOVY picture
Cheers , Craig
Cheers , Craig
- Kim Strode
CL Inlay
Great 'CL' inlay Craig. At some stage can you show a novice like me how you go about in inlay in the headstock like yours.
Regards, Kim
Regards, Kim
Kim Strode
Daylesford, Australia
Kim, I'll have to give the inlay thing some thought. I'm fairly busy with the adjustable neck thing at the moment . I'm sure there are others here who can help as well.
Not trying to fob you off here Kim but a search through some of the American forum archives on the subject will give you lots of information to start with. I'll help where I can, but don't really qualify myself as an experienced inlay artist to give a tutorial. Keep reading up on the subject and give it some practice runs.
Here is a picture of my very first inlay which took me a REALLY long time to finish.
Cheers Craig
Cheers Craig
I'm right with you there Dom !. I reckon they are 'Tops ' !Dominic wrote:Hey Martin, I have been getting into playing Oceans by John Butler and i absolutley must have/need an 11 string guitar now.
" Funky Tonight " .... WOW !
I hardly play my six stringers since I started getting into them . I'm still using twelve strings though . Why does he takes off the high 'G' ?
Cheers, Craig
Craig, I suppose it sounds better. The songs that I know he uses them (11 stringers) such as Oceans are in open C tuning(high-ECGCGC-low). There are 2 Gs so maybe the 2 high Gs screw each other up. Not sure. If I had a 12 I could do the experiment myself.
But while I have you here, can you point me to a nice bracing pattern for a 12?
I don't know for sure Craig but it may have something to do with the fact that the unwound "G" is so thin and under such tension when at pitch it has a tendency to break if an ant farts too close. Maybe he decided that with his style, having it there to snap mid performance and muting out everything it touches is more of a hindrance than a help.Craig L wrote:Why does he takes off the high 'G' ?![]()
Cheers, Craig
According to my string pack ( D'Addario ) the High 'G' has 27.9 Lb tension. The highest tension in the set, and also the thinnest. Maybe he's just sick of breaking them
I really like the high 'G' myself . I haven't got around to altered tunings as yet , but reckon there are a lot of possibilities.
Man this John Butler ( and his fellow members ) ROCK !
He has me dancing around the workshop playing my 12 . I don't know what I must look like. I'm certain he has made 12's more popular by demonstrating what they are capable of. My 12 is so alive ! I adore it !
I compensated each individual string at the saddle which I now think to be worth while ( not that Mr. Butler's is ,,,,,,as far as I know ). It means that it sounds more in tune up the neck than other 12's . This may be part of why some players pass over 12's.
Dom, I studied the Taylor bracing mainly , but looked at others as well. I did much as Martin ( our Martin
) has done. I made the third tonebar very small in the end . I also included A -Frame bracing between the soundhole and neckblock. The rest of the braces were increased barely 10 % in dimensions from a six string. My bridgeplate is a lot beefier though . Bigger in footprint and thickness.
Have a look at my "12 string finished " thread here on the forum ( Oct. last year ) . I think there is a pic of my bracing there . I won't post it here on Martin's thread or he'll call me a bastard again !
P.M. me if you want more details.
Everyone should make a 12 string or you're a bum !,,,, period !
Cheers Craig
Cheers Craig
No , I don't think that the right thing to do Martin . This is your thread on your build , and it's looking fantastic Too !.
Besides I don't want you to start calling me a bastard again and hurl Kiwi abuse in my general direction !
I don't know if you can revive my old thread or not , but that would be the way to go in my opinion.
Martin what sort of bridge are you doing ?
Users browsing this forum: Google and 60 guests
