Uke heel block size
colburge
Uke heel block size
Post by colburge » Fri Jun 28, 2013 8:35 am
Hi all
I'm currently building a tenor uke and don't have any plans to work from, so need a bit of help. The body shape / bracing and scale length was easy enough to work out (with help), but I am unsure of the heel/head block size and design. In particular, how much wood do I leave on the body side of the kerf cuts? I was thinking about leaving 25mm - 30mm and scalloping out the centre to lighten it up, just guessing though.
Any suggestions
Col
colburge
Re: Uke heel block size
Post by colburge » Fri Jun 28, 2013 4:01 pm
colburge wrote:Hi all
Any suggestions
Col
I should of mentioned I am using the spanish heel method, otherwise the reference to the kerf cuts may not have made sense.
Col
ProfChris
Post by ProfChris » Fri Jun 28, 2013 6:52 pm
Anything above 20mm should work OK - even on a tenor there's not a huge amount of string tension. 25mm sounds like a happy medium.
Chris Reed
colburge
Post by colburge » Fri Jun 28, 2013 7:08 pm
ProfChris wrote:Anything above 20mm should work OK - even on a tenor there's not a huge amount of string tension. 25mm sounds like a happy medium.
Thanks Chris, I will run with that.
Col
Post by Allen » Sat Jun 29, 2013 5:35 am
I use 20mm inside the body
colburge
Post by colburge » Sat Jun 29, 2013 8:15 am
Allen wrote:I use 20mm inside the body
Thanks Allen
Col
liam_fnq
Post by liam_fnq » Sat Jun 29, 2013 4:07 pm
Thanks Allen
Col
I wouldn't scollop it though.
colburge
Post by colburge » Sat Jun 29, 2013 4:49 pm
liam_fnq wrote:
Thanks Allen
Col
Thanks Liam, I made it around the 20mm mark, and after seeing it, I wont be scalloping it, it would be a bit light on.
Col
Users browsing this forum: Google and 22 guests
