not something i would bother with normally as imho it is overated
others may disagree
always use a flat radius but i have a job that requires a compound radius approx 10" - 16" ish 24.75" scale
any one know if i could buy one ?
stewmac doesn't do a 24.75" - btw theirs are 25.5" only
I know i should do it but i really dont have the time to build the jig for a one off
compound radius fingerboards
Re: compound radius fingerboards
Do it yourself. I did my first with a compound 10-14(12th).
Used a block plane and a sanding beam. Easy. took ten minutes or so......Kinkade's book has it, and I'm sure you can find it on youtube.....
BTW Also not too impressed with the difference(?) if any over a regular radius.....
